Question Starter R&R........any tips?
I’m removing and replacing my starter this week. I printed the tech article and it seems pretty straightforward. Is there anything I should know or any tips on this R&R? Thanks in advance for your comments.
John
1997 993
2012 991
Old 07-31-2002, 03:42 PM
Navin Johnson
TimT's Avatar
hope you have some flexible arms, the top bolt is a bit of a pain!!!!!
'69 911 GT-5
'75 914 GT-3
and others
Old 07-31-2002, 05:19 PM
pwd72s's Avatar
UNHOOK THOSE BATTERIES...DOUBLE AND TRIPLE CHECK THIS!!!
(Don't ask me how I know...but "a friend" of mine has a 13mm craftsman wrench with a weld like mark.)
Old 07-31-2002, 05:24 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Good luck John! Post some pics/lessons learned when you're done. Does this mean we won’t get to push start you next time?
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 07-31-2002, 05:25 PM
cary's Avatar
CLEAN THE HEX NUTS FIRST. TWICE.
When the driver fits right, it comes easy.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 07-31-2002, 05:46 PM
Here's some pix from when I replaced mine:
http://vintagebus.com/howto/starter/
Old 07-31-2002, 06:29 PM
Cool
schubee...not that you should follow my example..I'm into over-kill..a ground strap was run directly from starter bolt to tranny mount bolt...I use Loctite Graphite-50 anti seize, which is 2X as conductive as Loctite copper anti seize...this is in addition to stock ground strap under there...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-31-2002, 07:11 PM
Kevin Stewart's Avatar
I think the only trick is to get the car up real hi, (please use jack stands) crawl under and if i remember right the top bolt youwill have to rap your arm around the tranny (drivers side) to get to the top bolt, Kevin
Old 07-31-2002, 07:21 PM
pwd72s's Avatar
UH, any of you guys notice something different about Ron's CV joint in the pic??? Pay close attention...this is a test...
Old 07-31-2002, 07:43 PM
Yes its safety wired, must be a race car, Kevin
Old 07-31-2002, 07:47 PM
pwd72s's Avatar
Kevin, you get the gold star...but Ron would laugh at the thought of his road warrior being a race car...
Old 07-31-2002, 07:57 PM
Is he an Aircraft Mechanic?
'81 911SC Targa 3.6
Old 07-31-2002, 09:02 PM
Send a message via Yahoo to scarebus
A good aircraft mechanic will have the safety wire tighter
with a perfect reversed 'S'.
Old 07-31-2002, 10:44 PM
thrown_hammer's Avatar
I cut off an allen wrench and had it welded in a socket. This makes it much easier to get the top bolt from under the car without shoving your arm into dark scary places.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 08-01-2002, 04:09 AM
Disconnect the battery.
I too, learned the hard way.
Old 08-01-2002, 04:41 AM
Inari77S
Guest
Posts: n/a
Did mine Monday night. Took about 1:15, working in a tight garage. I used a Crescent wrench on the hex wrench to get enough torque to free up the top nut.
Does it make sense that the engine runs smoother since I've been under there? Only thing I can think of is that cleaning up the ground strap increased the spark current.
Did Porsche change the motor speed over the years? Or was my old one (original 77, by the look of it) so gummed up that it just couldn't spin as fast as the '82 replacement. The newer one sounds like it's ~3X faster.
Old 08-01-2002, 05:09 AM
Well, I decided to tackle this R&R last night BEFORE I read your comments…..duh! I followed Pelican’s tech article on this and it was fairly simple. One thing though, make sure your car has cooled down for this job.
I agree with the top flare nut being the most difficult to remove for this task. Damn that oil cooler is HOT! I didn’t approach it from the driver’s side. Having small skinny hands, I was able to guide my 10mm allen socket from over the top of the starter. After that, everything was a breeze.
Yes, the first thing I did was disconnect the ground on the battery. However, I could not find my ground strap on the passenger side of the tranny. Am I missing something here or did the PO change the location? I’m now curious on where the ground strap is.
John
1997 993
2012 991
Old 08-01-2002, 08:20 AM
Great job on the safety wire, but why is there a zip tie in the middle of the CV boot and NOT one on the out boot end?
Old 08-01-2002, 08:45 AM
Friend of Warren
My thoughts exactly! I would have to "redline" that CV joint.
Kurt V
Old 08-01-2002, 08:52 AM
