Idiot Warning Light
The battery idiot warning light on my 85' Porsche 911 lights up and stays on with intermittent start ups. The battery and alternator are both new and the system is charging properly. Loose bulb, fuse, wiring issue?? What are some cures for this problem.
Old 07-22-2013, 08:53 AM
schumicat's Avatar
check belt tension
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
RETIRED
Joe Bob's Avatar
That and grounds....
2012 ML350 3.0 Turbo Diesel
Old 07-22-2013, 09:41 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If the light comes on...does that mean an idiot is driving it?....LOL
Bob
Bob Hutson
Old 07-22-2013, 10:26 AM
RETIRED
Joe Bob's Avatar
Aren't we all, Bob?
Old 07-22-2013, 10:38 AM
wwest's Avatar
BRAND new alternator..? Slip ring brushes....
Old 07-22-2013, 10:54 AM
AAEEEEE!
It's highly likely it's the blue wire or ground. Check the voltage at battery while running, if its 12 volts steady then this means altenator is not charging the system. Unfortunately if this is the case you gotta open it up again.
Oops, read your post, says its charging properly ... Well then, is it over charging?
Laissez les bons temps rouler
Old 07-22-2013, 04:25 PM
Guardsred911's Avatar
Check the voltage regulator function too... I took my VR and alternator to a shop where they tested it all in conjunction with each other.... ended up having the alternator rebuilt...
J
911 SC - 1980
911 S - 1977
Old 07-22-2013, 04:35 PM
