Buy them, sell them
Adam's Avatar
Porsche Crest 2.7 Compression - update
Well, I'm breathing a lot easier now...
I went to visit my mech and to see my car. Turns out, my injectors were real bad.
They were:
1) Spraying fuel everywhere
2) Not spraying fuel
3) Dribbling fuel
4) Spitting fuel
The car had 5 exhaust valves which were very tight and two tight intake valves. This is all 8,000 since the heads were retensioned by the PO's mechanic after the rebuild. My mech couldn't believe that the valves weren't re-done after the heads were retensioned. Also, he's checked the head studs and they're holding up nicely.
So, after throwing in a new set of injectors and doing a thorough valve adjustment, my mechanic has fully restored compression to the two offending cylinders, which incidentally, had readings of 104psi and 98psi. Having poor injectors was "washing the bores" and with no oil in the cylinders, there was a lot of blow-by. Together with the poor valve settings, internal combustion had no hope, hence the lawnmower, 4-cyl sounds.
He's tuning the car this morning and changing the oil, so I will be able to pick it up tonight. My new Monty is on and the car is sounding STRONG! I can't wait to drive it!
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 08-01-2002, 06:21 PM
CamB's Avatar
Glad to hear all is well for (comparably) less money than you thought.
Ummm, you mention the PO. Is this someone you know
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 08-01-2002, 06:27 PM
Buy them, sell them
Adam's Avatar
Cam,
No beef at all with the PO. It's the PO's mechanic who I'm surprised at. I would assume that when cylinder heads are retensioned, the valves would naturally need to be done again.
Which mech would deliberately not do that when he knows that it would only be discovered later on? The PO was told all had been done and it was ready to drive for years and years.
The PO, btw, is my old high school buddy. Some of you might know him... Matt Holcomb!
Old 08-01-2002, 06:36 PM
Early_S_Man's Avatar
Porsche Crest
That is good news, Adam!
So, what did the compression on those two cylinders return to?
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-01-2002, 06:39 PM
Buy them, sell them
Adam's Avatar
I'll probably get the exact details tonight, Warren. I'll let you know. Thanks for your advice, though. My mechanic was very interested in the Chemtool "cocktail".
Old 08-01-2002, 06:48 PM
WydRyd's Avatar
FANTASTIC NEWS ADAM! Wooooooo Hoooooooo! See ya on Sunday
Old 08-01-2002, 06:50 PM
Cool
Adam...I do a routine oil analysis every 10k to stay on top of the situation, especially gas in the oil..I have to send off 3 samples to check for silicone in the oil, which is an indicator of dirt/dust getting thru air filter..I was using the K&N and saw a higher silicone than I liked and switched to stock air cleaner. I just did a big ride and was on dirt roads, so a good silicone reading will prove the point of using stock air filters. I use Oil Analysis Co., 1-804-526-1151 or L Turn9@msn.com ............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-01-2002, 07:26 PM
Bill Douglas's Avatar
Hey Adam, good news. And you'll be pleased to get that puppy back on the road.
Old 08-01-2002, 07:52 PM
CamB's Avatar
Yeah, I remembered that Adam - I was just stirring a little (you highlighted "POs mechanic" after all
1975 911S (in bits)
Old 08-01-2002, 07:53 PM
Adam,
E-mail this thread to Mike Garner; I'm sure he'd appreciate an update! Or, we could just place an ad for Mike in the next issue of Porsche Parade using a screen cap of your thread starter!
Matt Holcomb
MFIWDP
PRVC
BOHICA
1974 911 Carrera 2.7 RoW
1975 Mercedes-Benz 280SE
Dedicated Homepage
Engine Rebuild Homepage
Porsche Owners Gallery Profile
Pelican Gallery Profile
Old 08-01-2002, 08:05 PM
Sean Hamilton's Avatar
Thumbs up Bewdy. Let 'er rip! Adam
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 08-01-2002, 08:44 PM
