-   -   Recommended Air Flow over the front A/C condenser (http://forums.pelicanparts.com/porsche-911-technical-forum/762882-recommended-air-flow-over-front-c-condenser.html)
SilberUrS6 07-26-2013 04:40 PM
Originally Posted by Bob Kontak (Post 7570894)
I had to, "you know", to Penny from Lost in Space. I am as old as dirt.
Wow. :)
Good thing that wwest doesn't have any credibility any more. If anyone actually takes his advice, they probably deserve what they get.
Ronnie's.930 07-26-2013 04:51 PM
An interesting thing about wwest; he is very fond of belittling others for mistakes/misspeaks they have made (even when that person has acknowledged said mistake), yet he is so often wrong himself (though he never acknowledges his own errors)!
wwest 07-26-2013 04:52 PM
My creditability is only at risk if you are a half-brained idiot...
wwest 07-26-2013 04:53 PM
Originally Posted by Ronnie's.930 (Post 7570939)
An interesting thing about wwest; he is very fond of belittling others for mistakes/misspeaks they have made (even when that person has acknowledged said mistake), yet he is so often wrong himself (though he never acknowledges his errors)!
Has anyone yet to PROVE me to be in error...??
brads911sc 07-26-2013 04:57 PM
WWEST... should we find and post all the times you contradict your own postings?
We dont need to PROVE anything. They are your ideas. You fail to prove them. Therefore we can assume that since you refuse to prove them that you know them to be false.
Bob Kontak 07-26-2013 05:01 PM
Now hold on there.
I was willing to spring for a "spansion" valve and have it tested for physical closure regarding the low/high pressure equalization post shut off argument.
You have stated that we are way beyond this issue.
How about this. I buy the expansion valve, send it to our friend in Canada and he tests it after his fifty-hundred month vacation. If I am wrong, I eat the $20. If you are wrong, you send me the coin.
Edit: Or are you a chicken?
SilberUrS6 07-26-2013 05:02 PM
Well, there's the offering of proof, and then there's the offering of proof that wwest believes.
Like his assinine idea that the high side pressure would go to 800psi (LMAO) and that somehow a 30-degree F temp rise of the rear condenser means that the pressure goes up more than ten percent somewhere other than the condenser.
These points are obvious to everyone but wwest. So yes, PROVEN wrong. With actual math and everything. But if the rest of the world accepts the proof, and wwest does not, then it's really not proven.
Hello, circular reasoning!
tirwin 07-26-2013 05:04 PM
<div class="pre-quote">
Quote de <strong>Ronnie's.930</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">An interesting thing about wwest; he is very fond of belittling others for mistakes/misspeaks they have made (even when that person has acknowledged said mistake), yet he is so often wrong himself (though he never acknowledges his errors)!</div>
</div>Has anyone yet to PROVE me to be in error...??
Yes. The problem is you fail to acknowledge it. And when confronted by evidence and observations from others you reject their data.
Everyone appreciates a lively debate. If you weren't such a Richard about everything by hurling insults and allegations you might find that people might actually respect your ideas. As it stands right now, it looks to me like you've dug yourself a nice little hole in the respect department.
Bob Kontak 07-26-2013 05:05 PM
I cannot comment on this perfectly logical statement for above stated restraints.
sacoffee 07-26-2013 05:06 PM
This reminds me of the days when I had an LS1 and the pecker size discussions went on and on ... But at least those were about performance debates. This asinine stuff is about a friggin air conditioner.
wwest is a troll .. This is his only entertainment, he enjoys this stuff and you all play into his hands.
Bob Kontak 07-26-2013 05:08 PM
Ronnie's.930 07-26-2013 05:10 PM
Yes indeed! You made a statement in one of Reid's infomercial threads that Porsche made improvements to engine cooling with the 964 - proof was offered that your statement was false, and that in fact, the 964 gave away considerable cooling efficiency in order to reduce noise emissions (curved blade fan which Porsche determined moves much less air, and under engine, sound deadening panels which retain heat).
Ronnie's.930 07-26-2013 05:11 PM
And apparently, you have as well . . .
friendly 07-26-2013 05:44 PM
@sacoffee--I never knew what a troll was until I tried to learn about my A/C on this forum. First, I Googled the term. Then, I read wwest and KelogGes on the forum. Then I placed both of them on my "Ignore list". Then I learned what an "enabler" is by watching people feed and quote the troll.
D@MN!!!
sacoffee 07-26-2013 05:54 PM
... the prosecution rests
friendly 07-26-2013 06:22 PM
This is so sad...
Ronnie's.930 07-26-2013 06:23 PM
D@MN!!!
So in other words, you've learned quite a bit from reading the a/c threads - good deal! :D
friendly 07-26-2013 06:28 PM
I have gone to Rennlist and its the same thing there. Post a legitimate question, get a troll. Pretty soon nobody follows the post.
Too many enablers and it only takes one. This is how trolls get their rocks off!
DUH!!!
wwest 07-26-2013 06:28 PM
Originally Posted by Bob Kontak (Post 7570965)
Now hold on there.
One better, if the TXV doesn't close fully in the required conditions I'll sent you $200.00.
But...What's to prevent it from fully closing if the conditions require a full closure, say the evaporator core already being a block of ice.
Bob Kontak 07-26-2013 06:30 PM
D@MN!!!
You have 26 posts. One recommends putting Armor-All on engine hoses, another tells someone there are two lights in some compartment (barn find). That is your total contribution to the forum. The absolute and complete summary of your toil regarding helping fellow Porsche owners.
You want us to assume that you understand what is going thru our heads regarding some off the wall loser that pisses on and confuses people that ask legitimate questions?. Are you really certain you are ready to guide us given your investment here?
Bob Kontak 07-26-2013 06:39 PM
Will respond tomorrow - girls from the strip club just arrived.
friendly 07-26-2013 06:40 PM
"thru out heads"...err spell check
"off the wall loser that pisses on and confuses people that ask legitimate questions."...you got that right.
If you read my previous posts and didn't understand them, you should've questioned me at the time.
Meanwhile, with all due respect, what does your post contribute to the original question??
wwest 07-26-2013 06:47 PM
Again, falsely stating it does not make it so. If you can find any place wherein 800 PSI was proposed as factual you will have earned my abject apology. Many A/C systems of a compariable period have BOV's ranging from 350 PSI to 450 PSI ,supposedly to prevent damage to other system components. One of our legacy systems might easily exceed those numbers post engine shutdown in an adverse climate.
The 30F rise was the result of a test to prove that the high side pressure would RISE post engine shut down. It was not intented to replicate what might be the worse case for that situation.
Proven wrong...NOT.
Ronnie's.930 07-26-2013 06:49 PM
DUH!!!
I understand your point, however, I do not care if wwest is getting his rocks off or not - if he writes something that I think is in error, I am going to challenge it. What goes on in these threads is debate. Sure, it can get silly, but of course, you are not obligated to read any of it.
sacoffee 07-26-2013 06:49 PM
Wow! I don't know Mr. Friendly but obviously you "trolled" him enough to research his posts so you coul find some evidence to prove your point. Congrats on your 4000 plus posts and thus your investment.
Good bye to another thread about air conditioning :rolleyes:
wwest 07-26-2013 06:51 PM
A link, please, even "pretty" please...
Bob Kontak 07-26-2013 06:52 PM
Check my edit time out where I corrected it, Slick.
I read all your posts. It's a function you will learn if you hang around.
With all due respect - Yawn. I got you pegged.
Bob Kontak 07-26-2013 06:59 PM
see post 8
sacoffee 07-26-2013 07:02 PM
Tough crowd
sacoffee 07-26-2013 07:03 PM
Originally Posted by Bob Kontak (Post 7571141)
see post 8
Yep, now on 70
Ronnie's.930 07-26-2013 07:04 PM
see post 61
How are the strippers treating you? :D
Ronnie's.930 07-26-2013 07:07 PM
It seems to me a bit odd that some of the people here accusing others of "trolling" are doing just that - trolling for an opportunity to pass judgment and advise others on how to conduct themselves.
Bob Kontak 07-26-2013 07:14 PM
Originally Posted by sacoffee (Post 7571146)
Tough crowd
Overall not really. I am just a prick.
What needs to be understood is that wwest is a cancer. It has been going on for years, One cannot walk away from unsubstantiated BS if someone else may rely on it.
Other car furums, sure. Here, no.
friendly 07-26-2013 07:14 PM
I just want to learn more about my Porsche.
Bob Kontak 07-26-2013 07:24 PM
Now that is something we can agree on. That is what will keep you here and that is what will piss you off when you see all constructive thought fly out the window at the expense of some hapless poster who trusts other posters to set them straight.
Bob Kontak 07-26-2013 07:26 PM
They get mad when I type.
pc100porsche 07-26-2013 07:36 PM
http://forums.pelicanparts.com/uploa...1374896157.jpg
Penny ?
Ronnie's.930 07-26-2013 07:41 PM
As requested -
Amazon.com: The Art of Living Ego-Free eBook: DA Southern: Books
SilberUrS6 07-26-2013 07:44 PM
Originally Posted by sacoffee (Post 7571147)
Yep, now on 70
And the folks who complain about the troll and his responses contribute exactly what knowledge to the OP?
That's the irony of complaining about how threads get off-track.
The threads get off-track with malice aforethought on wwest's part. He is so hell-bent on continuing his jihad against Griff that he will do ANYTHING to insert himself in ANY AC thread, regardless of applicability of his "advice".
He will then prevaricate and change the subject in order to derail the thread. Making sure that nobody follows his idiotic advice is more important than preventing forum clutter. Eventually, Wayne or someone else will finally tire of wwest's antics and send him packing. Until then, debunking of the preposterous claims must continue, lest some poor soul actually take his half-baked advice, or consider his "logic" as sound.
sacoffee 07-26-2013 07:49 PM
Fair enough
