Recommended Air Flow over the front A/C condenser
Well the title pretty much says it all.
Is there a Porsche spec that specifies the recommended amount of air (measured in CFM) that should flow over the front A/C condenser? I am ready to install that component and wanted to know what the Fellas in Stuttgart thought. Thanks |
It is not much, that is for sure. With the AC system running that fan does not produce a lot of volume. If you put your hand under the front bumper you can feel warm air sort of oozing out. Since I have 3 other condensers I don't figurer it does a lot on my car.
The factory tube and fin condenser does help a smidgen in stop and go traffic but quite a lot underway at a decent roadspeed.
The aftermarket ones seem to rely strickly on the low volume HIGH noise content of that front fan as every one of those appear to be designed to BLOCK airflow due to roadspeed. |
How could this be? If the fan helps the factory how could the fan not help the aftermarket one.
I would think that the aftermarket would be as good as the stock. I really would also be interested in putting a better fan on those units. Seems like if you could get better airflow it would be Better than a spal fan on the deck... Quote:
Do you have a chin spoiler? Seems like that would also make a big difference in the amount of airflow.
What a joke this guy is. Why he is not sent to the island for harassment is beyond me. |
I agree Bob. Pelican Must really not care about the continued assault on products they sell and endorse. Seems strange to me.
Within a small handful of posts we are down the rat hole again. The OP routinely is confused and disengages. The thread dies from being valuable once wwest posts and receives push back.
No benefit to discussing the original topic as continuity is gone. It's disgusting. |
I measured airflow with an anemometer and made some rough calculations. I've posted the numbers before if you want to search my username. What follows is strictly from memory so I may be off.
IIRC the flow from the factory set up is only around 320 CFM. The motor from a Carrera footwell blower is almost a straight drop in and will increase flow rate to 450 CFM. You have to fiddle with the wiring hook ups but the motor physically fits. Again from memory the condenser motor spins around 3k rpm and the footwell motor closer to 5k rpm. With a footwell motor installed noise increases significantly. Not enough to hear inside the car but everyone around you will know it's on. The factory condenser fan actually blows just enough to create a circular flow pattern. Someone else here, posted a diagram. I didn't think of it but I did come up with a redneck test for it so I could demonstrate for my daughter. The fan is set up over one end of the condenser and the plate it sits on has a slight peak. Air flows down on the driver's side and up on the passenger's side. Go the the bathroom and grab a single square of tissue. Turn your A/C on and key to the run position so the fan is blowing. Holding the square flat in your hand try to place it flat against the condenser cage on the D/S of the car. Can't be done. Now try the same thing on the P/S of the condenser. Airflow on the P/S of the condenser will pull and hold a tissue against the bottom of the cage. As WWest noted 911 A/C works much better at speed that when stationary. What he continues to ignore is that front condenser airflow at speed is not front to back. It's top down. WWest denigrates the design of aftermarket front condensers while ignoring the evidence that they actually work better. When the car is at speed air is flowing under the car and past the condenser. The air flowing past the condenser is pulling air through the condenser. The flow at speed is still limited by the fact that any air flowing through the condenser must be sucked in through the small hole in the front of the tub. -J ETA - I ran a footwell blower motor last summer. The extra airflow definitely helped prevent vent temps from climbing when the car was stationary (at a stop light,etc). I'm not sure that it did a lot at speed. I eventually pulled it and went back to a regular condenser blower motor. -J |
I found the link. http://forums.pelicanparts.com/porsche-911-technical-forum/427532-cfm-front-ac-condenser-fan-2.html |
Good info. Guess we have another case where wwest is full of bs on which he has no proof other than his own dreamed up theory. Post your videos wwest. Just because the front condenser seems to do nothing at 70 degree ambient where you live doesn't mean it doesn't work at 95 degree ambients. Probably should just shut up so you don't continue to look foolish.
Insofar as the fan goes the aftermarket front lip condensers probably work better than factory, but since natural airflow arising from roadspeed is quite thoroughly BLOCKED then overall they are SNAKE OIL. |
Once you have would you please inform all of use just how those aftermarket front lip condensers take advantage of the HIGH LEVEL of cooling airflow at, say, 70 MPH. What is the front to back airflow path? |
But in stop and go would be more effective as a heat exchanger than the deck. At speed your spal on the deck does more harm than good as it blocks airflow. A better front condenser in stop and go would actually reduce engine temps. Think wwest think.
It's amazing how myopic one's view is when they are fueled by hatred.
At speed air pressure on the front of the car added to the blower fan creates a high pressure area above the condenser. Airflow under the car creates a low pressure area under the condenser. Airflow is top down. The faster you go the greater the airflow. $hit, my 10 year old knows who Bernoulli is. -J |
You have a lot of value to add wwest. I'll stick to my single argument. That is, your grudge is disruptive to the overall integrity of this forum - specifically AC threads. I do like it (a lot) when you beat on Lorenfb but he demonstrates behavior that is deserving of such. I ain't seeing that in the AC thread community as a rule. |
My system is pretty optimal at freeway speeds. With 85 degree ambient I got vent temps of 37.9 degrees. At 78 degree ambient temperatures I got 33.8 degree vent temperatures. Both times with low humidity. However, about town my vent temperatures ranged from 43-46 degree vent temperatures. Currently my system has front and rear condensers, but the front condenser does not have a fan or even the cut out in the front trunk to accomodate the fan. Of course I know as is these are great results, but with a properly installed front condenser fan I hope/dream to achieve the 30 degree vent temps about town. Based on the numbers JAR0023 provided, my lightweight nautical fan which produces 150 CFM may be a little short of his measured number of 320 CFM. Again thanks for the help |
http://forums.pelicanparts.com/uploa...1374855048.jpg Off topic - JAR - I do likes me some Possum. http://forums.pelicanparts.com/uploa...1374855247.jpg |
The condensor gets more cooling airflow AND the exhaust manifold is cooled thus lower the radiant heating effects. |
And your proof that it isn't? Testing? Data? Or you just make it up like all your other theories...
Thus endeth the lesson......................http://forums.pelicanparts.com/suppo...sun_smiley.gif |
Poor wwest.
@ Bob - Ah Valerie, nice photo. Coming of age in the early 80s she was definitely the focus of my...uh well, you know, attention.
@ West - You don't disagree in principle, so you want to argue degree? I'm not going to argue with you. You've shown over and over what a pointless waste of energy that can be. I've stated my opinion. You are free to disagree and keep believing what you want just like all your other pet theories that only you believe. The members of this board can read and make up their own mind. -J |
Did you ever look at our Porsche's sideview and realize, recognize, that the outline closely resembles an airplane wing. .??Airflow over the top must travel a longer distance therefore "lift" is created. What happens under the wing/car.... Think about the jet that just crashed at SFO...that idiot was flying so slow that the airplane would have stalled sooner were it not for "ground effect". Additional lift to/for the wings due to the "pressurized" air layer between the bottom of the wing and the water. Get a good enough front spoiler to divert airflow to the side(s) and then, maybe, you wouldn't have air PRESSURE, relatively speaking, below the front of the car. "Class" dismissed. |
Perhaps he is not as familiar with squirrel cages as you.
http://forums.pelicanparts.com/uploa...1374877406.jpg |
Ignore wwest. He is a sorry excuse for a man. An old bag of bones with no real knowledge. He spends all day and night trying to prove a point... And makes many false statements in the process...
wwest, the above is an example of deleting out text in quoted passages that is unnecessary. Highlight the unnecessary text, right click, select delete. Then just reply below the quote border. Literally this thingie on your screen(well, the second one) ----> [/QUOTE] It makes what ever you are saying appear more succinct and lucid. It's also easier for you as you don't have to bold and italicize your commentary in the quote field to segregate it. Not wailing on you. I have reached my quota for this week. :-) Sort of off topic - but not really, given how the AC threads go - and don't even think I am trying to suck up to your mean, grumpy-ass, crotchety, profoundly opinionated, conceited self - I service a 2004 GS300 "Sport" and I have never, ever been in a car where the AC is so astoundingly efficient. I think it only uses 20 oz of R134. |
Quota should increase corresponding with the number of stupid things wwest says...
| All times are GMT -8. The time now is 08:46 PM. |
