hi guys, can someone please tell me what the 10 or 12 pin plug is for circled in red, i found it unplugged as i removed the heater hose to change fuel filter.
also there is an orange connector of some sort (circled in blue), seems to be broken, i found a black wire not plugged into it.. thanks in advance ![]() ![]()
82 SC Targa Guards Red = Toy 04 E55 AMG Brilliant Silver = DD 04 Cayenne Turbo Platinum Grey on 22s = Previous DD 80 Wide body 12AT RX7 Black 350+ hp= Previous Toy 78 Alfa Romeo GTV Blue = My 1st Cool Car |
Kinda looks like Engine Fuel Injection Harness
Pelican Technical Article: 911 Engine Removal Made Easy |
weird, as my car is running without it being plugged in..
any one else??
Make America Great Again!
Definitely fuel injection harness... Look to the right of your cruise control, on the back shelf of the compartment. Weird it's running.
-- black one looks like O2 sensor connection -- Rich Last edited by Rich Gas; 10-24-2013 at 08:11 PM.. Reason: Stuff |
ROW '78 911 Targa
Euro model that has travelled the world?
What engine number do you have on the case below the engine serial number on the fan shroud? I'm only asking this because a harness customer of mine found out he had a '78 engine in his '82 just the other day!!! He didn't need any of the lambda wiring. Needless to say he was surprised! Last edited by timmy2; 10-24-2013 at 08:45 PM.. |
ROW '78 911 Targa
The only reason he found out was a picture he sent me showing his remote VR?
Made me ask a number of questions leading to him reading the engine case number. He has all the '82 CIS plumbing but all the wiring was removed. Said it runs well with the later narrow runner CIS on an earlier large port motor.
do i need the O2 sensor connected?
yes its a euro model that spent most of its life in Japan, will check the numbers when i get home...
Ahhh, you got a carburetor under the boot!
Helps keep the AFR's in compliance if you take the car to inspection and they sniff the exhaust |
Late RoW SC.........
Boss,
You don't need that 12-pin connector because your car does not have an ECU being a RoW car. The other unplug connector could be the OXS another extra plug you won't be using. Tony |
thanks everyone, the number i saw under the fan shroud is:
![]() am i looking in the right place? what story does it tell?
ROW '78 911 Targa
Hmmm, 64C series is US delivery according to Simon's site...
Take a look on the flat part of the case between the area where the serial number is on the support and the oil pressure sender, ( about where the shadow from the sender is in your picture) there should be another number stamped like 930/10 or 930/16 or 930/17. Simon's Porsche 911 SC Site Last edited by timmy2; 10-25-2013 at 01:34 PM.. |
ROW '78 911 Targa
Need help!
Your number should be in the general area where the picture in this thread shows it. |
That looks like US deliver engine, how do I find out what the rest of the car is?
Do I need oxs plug then? What about the other harness then? My registration paperwork says it was 1st registered in Japan in 1989, imported to New Zealand 2008, no history before 89. Maybe it started life as US sc and was changed to row look at a later stage..
ROW '78 911 Targa
If the wiring was removed to go back to euro spec and the car runs well, you don't need it. Pollution control was the main reason it was installed.
It really depends on what has been done. May have been a later engine swap. Check your vin number against the information on Simons site. Maybe the car was imported to Japan from the US instead of Germany. Look under the seats, are there any relays and small control boxes mounted? |
Had a look under passenger seat and there are relays and control box under there
Reiver
Probably just sitting there....when I converted my US '83 SC to a 930-10 row we pulled the box to go with the 930-16 (trade) as it will need it.
