JDaniel's Avatar
Lightbulb Clean your injectors w/o removal...
I happened to be watching some late night TV, and stumbled into a show called "Two Guys Garage" (or something similar to that).
They were doing a tune up on a late model pontiac and decided to clean the injectors. They unplugged the fuel pump, hooked up a can of compressed injector cleaner to a pressure regulator, attached it to the fuel rail, fired up the motor, and let it run until the can was empty.
I don't know if it was the hour or the booze, but it seemed like a great idea. Has anyone ever attempted this with their car? What was in the can? Does it work? It seems too easy. No, this was not an infomercial.
Dan Tolley
1987 911 Coupe
The Owner's Gallery
2006 Audi A4 3.0q Cabriolet
2003 Ford F-150 XL Lumber and Trash Hauler.
Old 08-02-2002, 08:12 AM
zuerchers's Avatar
funny, i saw the same show and was going to post the same question. speed channel is great isn't it?
1987 Carrera Targa
Old 08-02-2002, 08:54 AM
I've seen that show too. However, I prefer to do it the fun way.
Get a big bottle to Techron and pour into a 1/4 filled gas tank. Now take the car to a nice deserted windy road type of place and drive the hell out it, getting the engine nice and hot and running at WFO. Refill the tank to another 1/4 tank and repeat. Then fill the tank, drive till empty, and change the oil. Probably the same result, but much more fun.
Old 08-02-2002, 09:40 AM
Senior Member
Doug Zielke's Avatar
This is no big deal....Mr. Goodwrench does it every day at the dealership service dept. "Injector Service Special...$49.99...while you wait...."
Probably more of a concern (for CIS cars) than the injectors themselves, are the injector o-ring seals and shells. Mine we're so deteriorated, it's amazing the motor ran at all.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 08-02-2002, 10:05 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Berryman B-12 Chemtool. Pour a can in your tank and go. Your valves will be much cleaner. I was impressed when I removed my exchangers this winter to discover how clean the previously blackened-with-carbon valves were. I'm sure the injectors received the same treatment. Good stuff.
Kevin L
'86 Carrera "Larry"
Old 08-02-2002, 10:21 AM
don911's Avatar
My injectors are getting cleaned tomorrow. My fuel mixture is too lean. Fuel pressure is normal. Hopefully it is only dirty injectors that is causing the problem.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 08-02-2002, 10:29 AM
Navin Johnson
TimT's Avatar
you can get that injector cleaner from parts stores that service "the industry" i.e. local mechanics etc. You need to get a special hose that goes from the can of cleaner to the schrader valve on the injector rail. I think In all its about $50 to get the celaner and hose the first time 'round
'69 911 GT-5
'75 914 GT-3
and others
Old 08-02-2002, 01:50 PM
Great idea, only one problem, how do you get a schrader installed on a Carrera fuel rail?
Joe
Old 08-04-2002, 09:33 PM
About every 6 months my 3.2 develops a flat spot around 2-3K (lean is my guess - particularly when cold) and I run Techron through a tank or two. Seems to improve it and I attribute it to better spray from the injectors. The commercial treatment works similarly - just more potent stuff and probably does a better job.
I used to own a BMW/Benz repair shop and in the late 80s carbon buildup on valves was a big problem. We had one of these injector cleaners and the drivability was improved dramatically on some of the cars following treatment.
Joe Riley
84 Carrera Targa
69 911S Coupe
Click here for 911S project "updating as I go"
Old 08-05-2002, 07:06 AM
