Intermittent Skipping / Choking
Guys - I'm loving my new 89 911 but getting a little frustrated with some small issues.
Once the engine is warmed up, the car will choke or skip, almost like I've hit a wall or a giant pothole. I've noticed it happens most often around 3k rpm when driving a consistent speed. On an hour drive on the highway it happened 3-4 times.
I took the car in a few weeks ago and my mechanic changed out all the wires as well as the distributor cap / rotor. The problem has either stayed the same or gotten a little worst since then.
I know I owe you guys some pictures - i promise to post on 8/10 after i give it a good detail. I'm not great with a wrench but I kill it with a buffer!
Old 07-30-2013, 05:49 AM
Discseven's Avatar
When's the last time the fuel filter was changed RG?
(LOL on the buffer!)
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-30-2013, 12:47 PM
Roger 911's Avatar
Could be a lot of things. How's your idle, steady, or does it fluctuate? Does it only happen at 3K, or do you get some sputtering poor drivability at other (lower) engine speeds?
I was getting some low engine speed issues with my 84 motor. It turned out to be an overly lean mixture. I adjusted this (for free) and it made a huge improvement.
This thread explains the procedure;
Idle Hunting -- The problem continues!!
But again, your problem could be different, and it may not be something your comfortable tinkering with.
Roger
'72 911 3.2
'18 Mustang Eco PP
'17 Mustang GT Conv
Old 07-30-2013, 01:12 PM
Here's a very simple test - when it skips, does the Tach drop rapidly? If so, it could be traced to either the speed/reference sensors or the DME relay, or the DME itself. If it doesn't drop, then I'd suspect something else, perhaps the common groove worn in the air flow meter sensor.
HTH,
Chuck.H
'89 TurboLookTarga, 361k miles
Old 07-30-2013, 01:18 PM
Thanks for the responses guys -
Car is perfect otherwise, no Idle hunting and no poor driveablity at low speed at all!
I don't notice that the tach drops rapidly - after reading previous threads I had been watching for this. To describe the issue differently, its as if i jabbed the brakes quickly and then went right back to the gas.
I will go through the records tonight and find out when the fuel filter was last changed.
Perhaps starting with the Air Flow meter sensor is the best bet?
Old 07-30-2013, 03:23 PM
Roger 911's Avatar
There is some interesting info on this forum regarding cracked solder joints on the DME circuit boards. My be worth reading.
Good luck.
Roger
'72 911 3.2
'18 Mustang Eco PP
'17 Mustang GT Conv
Old 07-30-2013, 03:48 PM
Fuel filter was changed in March right before i bought it. I'll do some reading on the solder joints on the DME today! Thanks again
Old 07-31-2013, 04:17 AM
The most common crack is on the coil transistor, the disc shaped one that stands up on the board and is attached to the heat sink.
BTW, I have found a new method to search for cracked solder joints that has worked for me - take high resolution photos of the circuit board (using a tripod or stand for stability) and blow the images up on your computer screen.
Chuck.H
Old 07-31-2013, 05:02 AM
