speedman's Avatar
More A/C questions
I can remember seeing a post about insulating the air ducts with some type of insulation, but I cannot find the post. Does anyone know what was used to insulate the ducts?
Rick T
Old 08-01-2013, 05:50 AM
Go-Kart Mozart
JAR0023's Avatar
That was probably me. I know I made a comment about it. Don't have a great answer for you. I just observed that there is some, I don't know how much, "cold" lost to the trunk with the 911 A/C layout. Whatever you use you don't want it to absorb moisture.
You can by insulation for home HVAC ducts that is basically two layers of bubble wrap with a reflective foil backing sheet on each side. Should be light and not hold moisture.
Couple of the older A/C install threads here have good documentation for insulating the EVAP box. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 08-01-2013, 06:09 AM
