| steeler1 |  Front wheel on 1989 911
			I want to change my front wheels out on my 1989 911 I don't like the 6x16  can I install the 8x16 without modification.
|  03-24-2013, 04:59 AM |
| Registered Join Date: Oct 2008 Location: Denver, CO
			If you're talking about 16" 911 offset fuchs, I don't believe so -- wide body (turbo  and turbo look) came with 7x16 up front, which can work up front on a narrow body carrera, though you'll likely need to roll the inner lips of the front fenders to keep the front tires' sidewalls from rubbing.  Porsche also made an 8" fuchs wheel for the 944 turbo (951) that looks very similar to the 7" 911 fuchs but will fit over bigger brakes. I believe that this wheel will fit up front on a narrow body 911 with the same fender rolling caveat stated above. | ||
|  03-24-2013, 05:12 AM |
| Northern Motorhead |
			I had 8x16  inch 951 offset Fuchs along with 9x16 inch rears when i had 16 inch wheels on my car and the fit was perfect.You might want to roll your front fender lips, all depending on how low you want your car to be ... Cheers ! Phil
				__________________ Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 | ||
|  03-24-2013, 07:12 AM |
| Registered Join Date: Apr 2010 Location: Houston, Tx
			If you want to install 8s in the front, I believe it will have to be with the 951 offset and it more than likely will require work.   For some folks (it depends on the chasis, each car is different) a carrera 7 inch may work in the front without any modifications. If you install 951 offset 7s, this is the safest bet for not needing work.
				__________________ "Simplicity is supreme excellence" - James Watt | ||
|  03-24-2013, 09:02 AM |
| steeler1 |
			Thanks for the help   I will probably go with the 7x16   | ||
|  03-24-2013, 01:52 PM |
| Grand Am/IMSA Data Guy |
			I did the 944 T 8" on the front of my 84 and rolled the lip, nothing extra.  Those wheels are probably pretty rare as I think they only came on the rear of the 85 944 T.
				__________________ Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ | ||
|  03-24-2013, 04:39 PM |
| Registered User Join Date: Jul 2012 Location: SoCal
			My 205/55-16 Hankook RS3s on 7" fuchs rub on the front fender at about 9 o'clock.  I think these tires run very wide.  Looks like I need to roll the fender just in a small area.
|  08-01-2013, 10:13 AM |
| Registered User Join Date: Nov 2010 Location: Discovery Bay, ca
|  08-01-2013, 10:30 AM |
			Double Post!!
|  08-01-2013, 11:15 AM |
| Schleprock Join Date: Sep 2000 Location: Frankfort IL USA
			Regular 16x7 and 951 16x7 have the same offset = +23mm.  However the 951 wheel has a deeper hub section with countersunk lug holes.  This makes the wheel actually look more like a 16x6 from the outward appearance. 16x8 front has to be teh 951 rear wheel with offset which is +23mm (incidentally same as the 16x7) The rear 911/930 16x8 offset is +11mm and that pushes the wheel too far out. I honestly think the 16x8 up front is a bit much for just a street car. The 16x7 is sufficient with a 205/55 on it. Put a 225/50 on the 7 and it's too fat IMO, despite it being the "standard" size that came on the rear of the car.
				__________________ Kevin L '86 Carrera "Larry" | ||
|  08-01-2013, 12:58 PM |
| Registered Join Date: Jun 2009 Location: ohio
				 | Quote:
 i had the same problem with my rs3 on a 7" wheel, but mine only rubbed on 3 corners at mid-ohio with the car lowered a bit. for normal street driving it was fine.
				__________________ - He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. | ||
|  08-02-2013, 04:38 PM |
| Registered Join Date: Oct 2007 Location: East Coast USA - Tysons, VA
			I'm looking for a set of 6X16 if you want to sell yours!
|  08-02-2013, 06:15 PM |
| Tags |
| bmw 328i coupe , porsche 911 cabriolet |
