Always Be Fixing Cars
Any reason I can't adjust intake valves first?
Going to be doing my first valve adjustment this weekend - am I missing anything or would it be fine to not drain the oil and start with the intake valves only? Access is far easier (no a/c) and I think it'll give me a good intro to the procedure. Going to couple it with a compression check.
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
You can do that. Don't have to drain oil to do exhaust if you jack up that side of the car....
Best if Compression ck did with a warm engine and then let cool overnight to do the valves.....G'luck
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Got it, thanks.
If I don't finish the valve adjustment for whatever reason I'm guessing its best to put the valve covers back on with the original gasket and not ruin my (non reusable) new gaskets.
OCPO
R-mm
Let me know If you need a hand with this... Would like to see how it's done
2018 X5 86 911 Targa 3.2 80 Mercedes 450SL 2006 530xi BillyBoat/H&R's....gone |
Won't say no to some help... I'll send you an email.
it will take longer that way, because you typically would get the engine at TDC for #1 cylinder and do the intake and exhaust valves before rotating engine 120 degs. and doing the next one. you have some increased chance of losing track of where it should be rotated your way.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
I'm assuming you're using the traditional method (backside you have to have both covers off simultaneously).
If this is your first time, I think you're making matters more difficult than they have to be. Accessing the intakes is not easy. The exhausts, on the other hand, are right in front of your nose (I'm assuming you're removing the cat/cat bypass) and you can practice getting the feel before moving on to the intakes. I just did this my first time, and while ultimately a satisfying job, it is time consuming and tricky. I would make it as easy on yourself as possible. Drain the oil, remove the cat (if you can), and check the clearances with the backside method before and after. Just my .02 -- good luck! |
Straight shooter
Pop the upper covers and lower covers off at the same time. I understand the Porsche wrenches are normally those of ritualistic behaviors but you can use your eyeballs to confirm the lobes that are aligned and also wiggle the rockers to check if they're in position for adjustment. This playing with crank alignment is for the birds and is a complete waste of time. Make sure the rocker pad is on the side away from the cam lobe and the rocker arm is loose (wiggle side to side). If so, proceed with adjustment of all in this condition. Once those few are done, bump the starter (plug wires are disco'd and nothing hanging where it can get caught up) over and check your remaining valves and adjust. Normally three bumps with adjustments and you're done with the adjustment. Keep a score sheet to let you know which you've done and check the box. 30mins job with this method and I prefer the front side to back side.
Cylinder Intake Exhaust 1 | | 2 | | 3 | | 4 | | 5 | | 6 | |
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Is there space to get an impact wrench onto the nuts holding he cat to heax ex, cat to muffler? Do these commonly need to be cut off?
Bentley tells me to remove the muffler to remove the cat - is this the easiest way to gain access to the exhaust valves?
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process Last edited by r-mm; 07-23-2013 at 06:43 PM.. |
Speed Dog's Chauffeur
Get extra feeler gage blades
Drain the oil & just get it done. It is not a 1600 VW motor. The rockers have a "ball pivot" against the valve and that can make valve adjustment a challenge. Use the Pelican 0.004 tool and make the gage just slide thru lightly tight. Get extra sets of gage inserts because they get trashed quickly. Inserts have to be bent and then slid into the gap which destroys the inserts in 1-3 valve adjustments. My valves do not rattle. Also, tight valves will give you the "blue puff" at start-up.
I have the pelican tool and three add'l inserts. Only reason for not draining the oil is because I have no idea how long this will take my first time round.
Banned
You may be able to get an impact wrence on some of the Cat nuts/bolts, but just be prepared to cut some of them off if they are really rusty. I used a Dremel tool with a cutting wheel to get mine off. Then I replaced all the Hardware with Stainless. I know it sounds like a pain, but you will only do this once. DO NOT REMOVE THE MUFFLER. It can be done quite easily with the muffler in situ.
And also, just do the complete job. You will do an oil change and a valve adjustment and then be good to go. Best of luck. And just remember that you can always ask the folks on this board should you run into any difficulties.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
If you are removing a rusted cat/cat-bypass, be sure to pick up new gaskets for its 3 different connections. Also it is recommended you take steps to prevent the new bolts you use from rusting - a search here will find you several options.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Chain fence eating turbo
I never understand why people drain the oil to do the valves. Not a whole lot comes out. Just seems like a waste of precious oil.
Is there increased valve guide wear when the valves are too tight -- or too loose? You're wise to factor in more time for the adj. -- patience is key. It might be better to do the job when you don't need the car for a couple of days. Reattaching everything -- valve covers, distributor, plugs?, etc. -- and taking the car off jack stands, and then doing it all over, while easy can be time consuming. Time might be better spent just finishing the job (?). |
Red Line Service
DON'T DO A COMPRESSION TEST FIRST. Sorry if someone covered this already, but ALWAYS leave the spark plugs in until the valve adjustment is done. If you remove the plugs, at least one or more of the exhaust valves will be open. If, when the spark plug is removed a small piece of carbon falls on the open exhaust valve seat you will get an incorrect valve lash measurement. Besides, if you have a tight valve you'll get a low reading anyways. So leave the plugs in, adjust the valves THEN check compression. If you insist on doing a compression test first, perform the compression test, re-install the spark plugs, run the motor for a bit ( to get rid of loose carbon) then let it cool to room temp and adjust the valves. Good luck, enjoy!
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Banned
There sure is some wacky "advice" being given in this thread . . .
OCPO
Which Ron?
