Unhappy Caliper Piston help
Hi folks,
I've been in the garage all afternoon doing rotors and pads. The first three went fine, but I can't push the capliper pistons back far enough on the last. Its the right front. I'm using the wood stick method from Wayne's book and have broken 3 pieces of wood so far.
Does anyone have any tips or advice?
I've got carrera brakes and am putting in Mintex pads.
Thanks!
Kevin
'87 Targa
Old 08-03-2002, 02:20 PM
Hilbilly Deluxe
emcon5's Avatar
big-ass "C" clamp?
Tom
82 911SC Coupe
GTI Cup #43
Old 08-03-2002, 02:24 PM
Early_S_Man's Avatar
Porsche Crest
Or, C-clamp style Vise-Grips!
Better plan on rebuilding those calipers soon, though ... binding pistons that hard usually mean rusted/corroded pistons and bore!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-03-2002, 02:28 PM
rstoll's Avatar
or this.
Robert Stoll
83 911 SC
83 944
Old 08-03-2002, 02:32 PM
Thanks for the tips so far. I'll go try the C-clamp. I was hoping a rebuild was not in order. Perhaps that will be next project.
Kevin
'87 Targa
Old 08-03-2002, 02:39 PM
Doug E's Avatar
I prefer to use one of the adjusting "C" clamps because they tend to have a greater span and with the slide tightener you can get it snug and then you spin the handle to get her tighter.
Just be sure to use either a block of wood or the old pad so that the pressure is evenly applied. I wouldn't advise on putting the end of the clamp on the edge of the piston.
Good luck.
Doug
'81 SC Coupe
Old 08-03-2002, 06:44 PM
Sounds like the piston is cocked in the bore. I did that a while back when trying to 'excercise' my pistons, tracking down my pulling issue. I had to remove the caliper and squeeze it back with a c-clamp. Bad news is, it was a rear caliper - you 930-brake people know what a joy those are to R&R!
Old 08-03-2002, 06:51 PM
billwagnon's Avatar
I had the same problem on my car and ended up rebuilding the rear calipers - the job was pretty easy (couldn't have done it without my dad's bright ideas and air compressor though).
Old 08-04-2002, 10:03 AM
