So I was just driving home yesterday, taking it easy, not drivng hard at all, and there was a overwhelmingly strong smell coming from the car. It's a 79 911SC and that stinky clutch smell that I'd gotten a couple times when I dumped the clutch too hard. That was the smell I was experiencing on the drive home-the whole way.
What the heck would cause that? Today I did not really notice it too bad. Today is a pretty cool day here in Denver, yesterday it was quite a bit warmer. Could it be that the clutch is going out? it's been 7 years since the rebuild of the tranny. I'm not noticing any slipping though...?? thoughts?
1979 911 SC 1974 OEM 911 Exhaust and Muffler - Modified to a 2-out Fiberglas Goodies, 17" C4 Cup Wheels |
cycling has-been
do you still have the rubber centered factory clutch?
73 911T MFI, 76 912E, 77 Turbo Carrera |
Air Cooled
Parking brake?
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Taking it apart is easy
+1 on parking brake. Comparable smell.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
Northern Motorhead
The rubber centered clutch discs only came on the 87-89 G50 cars if i'm not mistaking ...
Check your wheels and see if one is way hotter than the other,you may have a sticking/dragging brake issue ! Cheers Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
My 79 SC came with a rubber centered clutch that went out after a couple of years. It is my understanding that the steel springs were introduced with the later Carreras.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Spiderman
My bet is parking brake or a sticking caliper. Like someone else said, after a drive you need to walk around and feel each wheel so see if one is significantly hotter than the others. Or take a sniff.
Rubber centered clutch has nothing to do with "slip". You'll either have an extremely jumpy/bouncy jerk in the driveline if the disc is partially gone (happened to me) or no go at all if it fails.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Northern Motorhead
My rubber centered disc exploded on track two years ago with no warning, i was under the impression that they only came with the G50 cars to dampen vibration ... my bad !!!
Cheers Phil
Great info people, thanks! I'm goping to go drive it now and do the wheel heat check. Could very well be a sticky caliper as i do feel some noticable pull at the stop lights now. I'll be back...
Champagne on Beer Budget
double check the required spacing on the clutch release arm/clutch cable adjustment.
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
So justy drove around and could not get the smell to come, and when i checked the wheel temps all but the front right were slightly warm. the front right was pretty much cold.
