Nick Pell (guest)
Guest
Posts: n/a
Hey guys I'm changing the rear brake pads on my 78 911SC. I was able to get the old pads out but can't budge the pistons to make room for new pads. Also the outer pad was completely worn off and the inside pad still has 4 or 5 cm's left. Any suggestions?
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-07-2013, 01:36 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Get a rebuilt caliper from Pelican. Your caliper has seized pistons and requires a good bit of work to get it operational again. Or check out the 911 classifieds here and get a set of good used calipers.
Join the forum and discover a crapload of tech info you can search thru.
Kevin L
'86 Carrera "Larry"
Old 08-07-2013, 02:06 PM
