-   -   What is the fastest drop Engine time did you guys have? (http://forums.pelicanparts.com/porsche-911-technical-forum/764914-what-fastest-drop-engine-time-did-you-guys-have.html)
Neilk 09-01-2013 06:31 PM
Would anyone recommend putting the engine back in without the fan and carb's etc. to save having to lift the car so high, or will it be too hard to install all the ancillaries once the engine is in?<br>
<br>
TIA
I did that because it was too much trouble to get the car that high in my garage. It wasn't too bad, but it would have been easier to install everything on a engine stand.
Neilk 09-01-2013 06:33 PM
BTW, what does the average shop charge in hours to R& R an engine. Sounds like a decent pro should be able to do a carbed, non AC car in 4 hours without a problem.
Classic 09-03-2013 03:30 AM
Thanks Neil
Peter Zimmermann 09-03-2013 09:37 AM
Originally Posted by Marc Bixen (Post 7600617)
So when you guys want to time removing an engine on a calendar instead of a stop watch, Try something like a 996 or 997 Tiptronic Turbo w/4wd. That's when beer celebration really tastes sweet.
Just a little more work than a '67 912, huh? LOL! Calendar instead of a stop watch!
1-ev.com 09-03-2013 10:08 AM
My guess that Marketing Add-On is in place :D
1-ev.com 09-29-2013 02:21 PM
Hey guys, here is purpose of this post is to establish THE BEST way to drop the engine and NOT like Pelican said 10 hours... Sorry Wayne...
1-ev.com 10-21-2013 06:50 PM
Also, ATV jack http://forums.pelicanparts.com/porsche-911-technical-forum/772047-1st-drop-top-end-observations-questions.html#post7662503
with plywood like this
http://forums.pelicanparts.com/porsche-911-technical-forum/772047-1st-drop-top-end-observations-questions.html#post7663162
OR this
http://forums.pelicanparts.com/porsche-911-technical-forum/401955-supporting-engine-removal-3.html#post3952426
looks like not a bad idea... What do you think guys?
1-ev.com 03-23-2014 10:18 AM
Just wanted to add, some Fellow Pelican ideas, how to lift an Engine:
http://forums.pelicanparts.com/porsche-964-993-technical-forum/800744-engine-drop-begins-2.html#post7961237
and this
http://forums.pelicanparts.com/porsche-964-993-technical-forum/800744-engine-drop-begins-2.html#post7961924
JohnJL 03-23-2014 10:30 AM
i once dropped a motor in the middle of a lap of Eastern Creek when the motor mount bolts loosened...or likely werent tightened...
that makes mine "the fastest" since i was doing about 60 kmph and all you guys were standing still for yours...;-)
Bob Kontak 03-23-2014 10:34 AM
The ceiling hoist is nice if you want to take the time to set it up. It's also out of the way and can be used for other jobs.
Floor hoist has to be stored if you buy and takes up floor room but has the mobility of load function.
christiandk 04-03-2014 10:17 AM
Just under 2 hours dropping the engine on my 912E after work today, including complete removal of drive shafts and getting gunk in the eyes........
1-ev.com 12-29-2014 10:39 AM
Here go, I came across another Engine Drop solution:
http://forums.pelicanparts.com/porsche-911-technical-forum/818959-drop-engine-without-tranny-2.html#post8146741
1-ev.com 03-28-2015 12:41 PM
Also, I came across this article from Hotrod about Engine stands: Budget Engine Stands - Hot Rod Magazine
where "Cheapo" 750 lb rated stand held up to 2200 lb of load !!! with Grade 8 bolts...
http://forums.pelicanparts.com/uploa...1427571601.jpg
http://forums.pelicanparts.com/uploa...1427571664.jpg
