BTW, what does the average shop charge in hours to R& R an engine. Sounds like a decent pro should be able to do a carbed, non AC car in 4 hours without a problem.
Thanks Neil
My guess that Marketing Add-On is in place :D
Hey guys, here is purpose of this post is to establish THE BEST way to drop the engine and NOT like Pelican said 10 hours... Sorry Wayne...
Also, ATV jack http://forums.pelicanparts.com/porsche-911-technical-forum/772047-1st-drop-top-end-observations-questions.html#post7662503
with plywood like this http://forums.pelicanparts.com/porsche-911-technical-forum/772047-1st-drop-top-end-observations-questions.html#post7663162 OR this http://forums.pelicanparts.com/porsche-911-technical-forum/401955-supporting-engine-removal-3.html#post3952426 looks like not a bad idea... What do you think guys? |
Just wanted to add, some Fellow Pelican ideas, how to lift an Engine:
http://forums.pelicanparts.com/porsche-964-993-technical-forum/800744-engine-drop-begins-2.html#post7961237 and this http://forums.pelicanparts.com/porsche-964-993-technical-forum/800744-engine-drop-begins-2.html#post7961924 |
i once dropped a motor in the middle of a lap of Eastern Creek when the motor mount bolts loosened...or likely werent tightened...
that makes mine "the fastest" since i was doing about 60 kmph and all you guys were standing still for yours...;-) |
The ceiling hoist is nice if you want to take the time to set it up. It's also out of the way and can be used for other jobs.
Floor hoist has to be stored if you buy and takes up floor room but has the mobility of load function. |
Just under 2 hours dropping the engine on my 912E after work today, including complete removal of drive shafts and getting gunk in the eyes........
Here go, I came across another Engine Drop solution:
http://forums.pelicanparts.com/porsche-911-technical-forum/818959-drop-engine-without-tranny-2.html#post8146741 |
Also, I came across this article from Hotrod about Engine stands: Budget Engine Stands - Hot Rod Magazine
where "Cheapo" 750 lb rated stand held up to 2200 lb of load !!! with Grade 8 bolts... http://forums.pelicanparts.com/uploa...1427571601.jpg http://forums.pelicanparts.com/uploa...1427571664.jpg |
| All times are GMT -8. The time now is 11:36 PM. |
