Question 3.0 port size
Can I tell the port size of my 1982 SC 3.0 without removing the intake?
Old 09-20-2013, 05:26 PM
Yessir,..if the engine is original to the car.
You should have the 34mm small-port version.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-20-2013, 05:34 PM
Angry High idle
Hi Patrick Thanks for the thread. Help- I installed an electromotive crank fire and have a problem with high idle. The throttle linkage sticks at the pedal, when I lowered the motor to change the pulley could I have bent the linkage? I can return the linkage at the engine. Thanks
Old 09-21-2013, 09:12 AM
ROW '78 911 Targa
timmy2's Avatar
Linkage could be hanging up on the transmission housing mount. Drivers side of transmission near the entrance to the body. Or as it goes through the engine tin.
Return spring(s) fall off?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-21-2013, 09:20 AM
