The Bavarian
Question Speedo output "A"
Hi,
while trying to track down the problem that keeps the cruise control of my '80 SC from working I found that the signal "A" from the speedometer to the cruise control brain (and the OXS milage counter) looks odd. Actually, the doesn't seem to be a meaningful signal.
Before I finally conclude that the speedo is shot, I would like to ask the following:
- What is the output configuration of "A"? is it a relay contact, a transistor, or what?
- How would a valid signal look like? I assume it would be some kind of frequency related to how fast the wheels turn. Is it a voltage (rectangular between 0 and 12 V)?
- Any other idea how I can check the "A" signal?
The speedometer is a VDO model 437.201/1/20
Thank you, Manfred
Old 08-11-2013, 06:58 AM
Manfred, I can't answer your question because my car is in the shop and I can't stick a scope on the A terminal. However, I never realised the A terminal was output for the OXS sensor - so you've explained why I've never had to reset mine in 30,000 miles (it's not connected)...
I'd expect it would have a good chance of being a 5V square wave output though - that's what you get from the transmission sensor.
'77 S with '78 930 power and a few other things.
Old 08-11-2013, 02:52 PM
The Bavarian
I'm glad I could help you. Hopefully I will find an answer for my questions, too.
Old 08-11-2013, 11:26 PM
The Bavarian
Bump...
I can't believe that no one has an answer for me
Old 08-12-2013, 09:03 AM
