odometer stopped working
My sons 85 Carrera's odometer stopped working, but the speedometer is still working. Is it the plastic gear or possibly some other problem. Where should we look first? Thanks Jerry
Old 08-12-2013, 05:25 PM
pete3799's Avatar
Most likely the gear has passed on.
Pete
79 911SC RoW
Old 08-12-2013, 05:33 PM
porwolf's Avatar
Happens to all of us eventually. It is probably the plastic gear. You have two choices: Either do the replacement yourself. Can be done, but not that easy. Plenty of threads here. Or, you send the speedometer to a repair shop like North Hollywood Speedometer, which is a highly recommended place on this forum.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 08-12-2013, 05:37 PM
ask around locally. I had mine done at a shop close to me. I'd only send to NHS for a complete refurbishment.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-12-2013, 05:42 PM
Could it be the cable that attaches to the transmission, or would that disable both the speedometer and odometer. Where does this cable attach to the transmission? Thanks Jerry
Old 08-12-2013, 06:15 PM
porwolf's Avatar
The cable attching to the transmission gets the signal from there. That signal, 8 contact closures per revolution of the main shaft, feeds the speedometer gauge. Both the MPH and the miles traveled work from that signal. If the speedometer reads MPH but the odometer does not work it's the broken plastic gear inside.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 08-12-2013, 07:16 PM
Thanks for all the input. looks like the plastic gear, Jerry
Old 08-13-2013, 06:46 PM
Fleabit peanut monkey
Bob Kontak's Avatar
If the trip odo says zero, you pushed it in while the car was moving. Ask me how I know.
1981 911SC Targa
Old 08-13-2013, 07:26 PM
87 - 911
Pull it out and send it to the good folks at North Hollywood Speedometer.
Have done mine and many others, also calibrated it, now the reading is spot on.
Old 08-14-2013, 04:41 PM
RETIRED
Joe Bob's Avatar
The speedo guy at NHS tole me that was a myth.....
2012 ML350 3.0 Turbo Diesel
Old 08-14-2013, 05:44 PM
