odometer stopped working
My sons 85 Carrera's odometer stopped working, but the speedometer is still working. Is it the plastic gear or possibly some other problem. Where should we look first? Thanks Jerry
Most likely the gear has passed on.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Happens to all of us eventually. It is probably the plastic gear. You have two choices: Either do the replacement yourself. Can be done, but not that easy. Plenty of threads here. Or, you send the speedometer to a repair shop like North Hollywood Speedometer, which is a highly recommended place on this forum.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
ask around locally. I had mine done at a shop close to me. I'd only send to NHS for a complete refurbishment.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Could it be the cable that attaches to the transmission, or would that disable both the speedometer and odometer. Where does this cable attach to the transmission? Thanks Jerry
The cable attching to the transmission gets the signal from there. That signal, 8 contact closures per revolution of the main shaft, feeds the speedometer gauge. Both the MPH and the miles traveled work from that signal. If the speedometer reads MPH but the odometer does not work it's the broken plastic gear inside.
Thanks for all the input. looks like the plastic gear, Jerry
Fleabit peanut monkey
If the trip odo says zero, you pushed it in while the car was moving. Ask me how I know.
1981 911SC Targa |
87 - 911
Pull it out and send it to the good folks at North Hollywood Speedometer.
Have done mine and many others, also calibrated it, now the reading is spot on. |
RETIRED
The speedo guy at NHS tole me that was a myth.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
