Fubawu's Avatar
Your must haves for a 3.2 build!
Hi
A friend and I are just starting a build on a 3.2 for my 71. I believe the current
motor has issues with one or more of the con rods. Either way what would
be on your list of must haves. Parts ,specs brands etc. I currently have freshly rebuilt Zenith's 40 for it with MSD ignition. I thought it would be nice to get some advice/input from those in the know. I was planning a mild rebuild but if it's open why not give it a little more attention. Thanks for any input.
Cheers
John
www.machine-motorsports.com
1971 911T 3.2 1971 911S 2.5
1972 911S 2.8 1972 911T 2.7
1965 911 300760 1976 911S
Old 08-14-2013, 07:59 PM
Porsche fanatic
jager911's Avatar
What's your budget and intended use? You could do cams, ARP rod bolts, hi-compression pistons, twin-plug, ported heads, flowed intake etc etc if money's no object.
On a budget, maybe cams, headers (if heat is not needed), M&K muffler and tuned Motronic, I wouldn't put carbs on my 3.2, too much tuning needed.
Do a search, it's all been done before.
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 08-14-2013, 08:37 PM
Burnin' Rubber
Koizumi's Avatar
Supertec studs: no more worries.
Old 08-14-2013, 10:04 PM
Bad LT
Uncle's Avatar
Scotch.
Ex Porsche Cup car with some boost and stuff.
Old 08-14-2013, 10:24 PM
a.k.a. G-man
Geronimo '74's Avatar
Supertec headstuds, arp rodbolts, 964 cams, new (sporty) valve springs, Ti retainers....
Old 08-15-2013, 12:35 AM
Fubawu's Avatar
Thanks for the input guys, I also have European Headers and exhaust. The Carbs were already on the car so I am going to stick with it. I am in the process of trying to get 964 rsa cams.
Old 08-15-2013, 04:10 AM
Twin plugged set up..i have a kit just removed set up for 3.2 case.
twin dizzy, plug wires w/ MSD. Drill the heads on your case, plug
and play..
Old 08-15-2013, 04:34 PM
