#000-044-800-12 adhesive kit that you don't need: #000-043-203-42 here is the service bulletin: http://www.pcarworkshop.com/images/f/fa/Third_brake_light_6638_1996_660396.pdf ![]() You don't need a 993 rear glass. I happen to put one in and did this as well.
1988 Carrera Coupe |
Taking it apart is easy
^^^ Thanks for this. One creative challenge would be to get the wiring through the roof (my car is a '74), and that looks like a tough one for someone with my clumsy fingers. Anyway, I'll look into it. Really nice appearance to it.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
OsoMoore & Jack Stands: Thank you for the helpful comments and guidance. I'll let you know how I made out over the weekend. Steve
OsoMoore: with my kids' karate classes and soccer games, I didn't get as far as I had hoped. I moved the deck to the side as you noted, and fed the power and ground wires through the hole and into the engine compartment. There is one ground spot behind the fuel filter. I removed the strap around the filter but couldn't move the filter enough to see the nut for the ground spot. Therefore, I have given up on that ground spot, and instead am planning to use the other ground in the engine compartment on the left side intake. Currently, there are three lugs at that spot from the ECU. My current problem is that I passed 18 wire through the hole, and the lugs from Sears that fit the .25 inch post are for larger diameter wire. Tomorrow, I plan to search Home Depot for the properly sized lug. Otherwise, I'll just double over the stripped end portion of the 18 wire and crimp.
As an aside, while I was working on my car in my driveway, I took a break and went in the house, leaving the doors and the engine hood open. There was a knock at the house door. Some guy I've never seen before asked if he could look at my car and chat about it with me. Has that ever happened to you before ? I was initially alarmed, out it turned out that he previously owned a 911, but not a Targa. Thanks, Steve |
1982 911SC Wine Red Metallic OMG I love this car! |
different type
I went old school..
1982 guards red 911 sc work in progress
Happens to me sometimes too!
It sounds like you have the hard parts done. Just make sure your connections are good and you should be all set soon. The epoxy I ended up using to secure the light finally did what sticky tape couldn't, and its been great. Now if only I could fix my drive train issue...
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
Member 911 Anonymous
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
OK Draco, I'll bite - how did you get the light so high up inside so that it does not interfere with the view behind? Which make of light did you use, and did you need to make a special bracket. More details please!
86FlatSix
blinking 3rd brake light
I experimented on installing a blinking module in my 3rd brake light. It helps get the attention of the person following me. Here is a test video showing how it blinks (5X) on initial brake press and then turns solid. If you brake within 8 secs in stop and go lights are solid. It will only blink if you press the brakes again after 8 secs.
https://www.youtube.com/watch?v=RqNfHx3A-r4
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
JQ911, I like that fast pulsing! Which module did you buy, please?
86FlatSix
Blinking Smart Stop - Flashing Brake Light
It is a perfect fit OEM light from a 2014 CAYMAN ( 2015 will work also ) Dealer price is about $140-150 ebay $80. He used a vinyl strip and cut to place. I guess you can also use windshield glass tint
I wonder how it would look in a Targa? I installed a Hella LED provided by DStern last year. Gotta admit I like this much better. Very clean
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 |
+1 DStern's LED TBL for me. Unfortunately, the CAYMAN TBL will not fit our Targas.
Third Brake Light on my SC!
I like the light the LED throws from the DStern 3rd brake, just like thin look of the pictured one.
Realistically, the DStern light only extends down a 1/4" at most from the targa bar. That is a 1/4" I am happy to accept due the the collision avoidance the light gives me. I elected to mount the light at the top of the rear window. ![]() Sent from my iPhone using TapatalkMOV_1626.MOV.mov
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 03-13-2015 at 09:41 AM.. |
These are all great ideas. Here is a picture of mine:
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
