Noel's Avatar
Wiring Oil Cooler Fan. Help decoding the wires from the relay socket.
I'm in the process of wiring an oil cooler fan for the Carrera cooler that is about to go in my car. The tech article is great except for one thing. I bought the relay socket but I can't tell which wires contact which holes in the socket. (Damn molded plastic)
Here are the colors, anyone know which is 30,85,86,87 & 87A?
Grey
Red
Brown
Red w/ white stripe
Red w/ white stripe
Many thanks,
Noel
Old 08-05-2002, 05:47 PM
Hilbilly Deluxe
emcon5's Avatar
I don't remember which color was which, but do remember it only about 2 minutes to figure it out with a multimeter and mark them all.
Don't do what I did, and mirror-image the relay plugs and the socket. As in, everything that should be on the left is on the right...
Tom
82 911SC Coupe
GTI Cup #43
Old 08-05-2002, 06:03 PM
Wink
I sorted mine using a test lamp.
Red (power in) pin 30
Red/white (power out) pin 87 & 87a
Grey (relay circuit) pin 86
Brown (relay circuit) pin 85
Mark
Old 08-05-2002, 06:30 PM
The pin out is for a 87 carrera.
30 RT (red) switched power from fuse box (16A)
85 GR (gray) controll signal (ground via the temp sender)
86 RT/SW (red/black) relay power from fuse box
87 SW (black) switched power to fan motor)
87a not used
Or go to the dealer and get the following harnesses
911 612 804 00 harness temperature switch oil cooler
911 612 805 00 harness blower oil cooler
The above should have the relay base and correctly colour coded wiring for a 87 with oil cooler temp sensor and fan.
Good luck
Chris
Old 08-05-2002, 06:45 PM
Noel's Avatar
Thanks guys. You are the best!
Old 08-06-2002, 04:48 AM
