G50 separation from engine - fork shaft - slide hammer
So have my engine and transmission out and would like to now separate them - working from bentley it advises to remove the retainer clip from the shaft and using a slide hammer pull the internal shaft. I bought a slide hammer 5/8 end - what adapter do I need to fit the internal shaft to pull it? Are there other ways to remove?
Old 08-21-2013, 10:14 PM
The cross pin is 6mm inside thread. I use a long 6mm bolt and thread it in, vise grip the head and tap out with a hammer.
Bruce
Old 08-22-2013, 03:58 AM
A slide hammer with a fork attachment and 90 degree bend will also work. Screw in the M6 bolt, slide the end of the fork over the bolt head, and use the slide hammer on it. Does not take much force. It is a slide fit.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-22-2013, 07:25 AM
Grand Am/IMSA Data Guy
Porsche84's Avatar
Porsche came up with a modification on this rod and bearings in the late 80's. If it is an early one without the upgrade they can be really tough to get out. I'll try to find the tech bulletin and post it. Get a long 6 mm bolt to use to reassemble, something like 6" long, that makes it easier.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 08-22-2013, 04:37 PM
DO NOT get crazy with the slide hammer or the shaft ears in the bellhousing can break off. spray with WD through the hole in the bellhousing and just light little taps until it comes out. it may just slide out anyway.
206 637 4071
Old 08-22-2013, 06:36 PM
Does anyone have a pic of this process?
I'm unfamiliar what a slide hammer does and what exactly I am supposed to do here....
1987 Porsche 911 Carrera Coupe
Old 10-08-2017, 11:26 AM
Remove the side retainer, insert a long 6 mm bolt. Vice grip the bolt and tap out the cross pin. Everything comes apart with the cross pin removed.
You will need the brass bearing update kit to replace
Bruce
Old 10-08-2017, 12:32 PM
Bruce
OK... thanks. I tried it and was able to get it done.
Old 10-08-2017, 02:43 PM
