new oil cooler has too many holes?!
I have a replacement external (under fender) oil cooler (from PP
) for my 86 3.2, however it has two additional holes when compared with the old one (I have a Swiss import and believe the specs were different).One of the holes is 14mm and I intend to plug that with a sump plug and washer, but the other is 6mm? What's it for and how can I plug it? Thanks Rich [img]
Rich ![]() '86 coupe "there you are" |
ROW '78 911 Targa
I would guess the larger one is for a temperature probe to switch on the cooling fan.
No idea on the small one.
RETIRED
Plugs.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Porsche lists a plug for the 14 mm hole, but I have no idea what goes in the smaller one.
Part numbers for: 14mm plug: N-016-155-3 sealing washer: 900-123-007-30 |
RETIRED
Thermostat bunghole?
The smaller hole is probably for the mounting bracket. I dont it goes through in to the cooler it self.
Checked: its for mounting purposes:
911-87 mit der 3.6 V-Ram und alles spaß Last edited by Jaskas; 08-21-2013 at 11:25 PM.. |
You think it doesn't go into the cooler? It certainly looks like it does! And what mounting bracket? The old one didn't use the same mounting.
thanks for the replies Rich
Apparently the small one is for ground and does not go into the cooler - I will check!
Thanks all Rich
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Cooler.
Hope this helps:
![]() Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Oil Cooler.
checked this morning and confirmed that the small one does not enter the cooler. doh, I should have spotted this.
thanks to all for the help with this. Rich
Does not go through into the cooler. Does not need to be plugged.
That is the ground point for the factory fan thermo probe.
Chuck Moreland - elephantracing.com - vonnen.com |
