rear quarter mounted A/C condensor with fan
Anybody out there have a fan cooled A/C condensor mounted in the drivers side rear quarter that looks like this? The discharge from my compressor goes through this one first then continues on to the deck lid condensor.
Just curious?
John Adams
1980 ROW 911SC
Old 08-07-2002, 08:37 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
i dont have one...I could probably use one.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 08-07-2002, 10:53 AM
Early_S_Man's Avatar
Porsche Crest
No, don't have one. But, a VW Beetle setup that I once retrofitted to a '66 Beetle after converting to 12 Volts had twin condensers and fans mounted horizontally beside the transaxle ... and it worked just fine! Fans were a bit loud, though ... at stoplights it sounded a bit like a pre-flight run-up with twin Lycomings!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-07-2002, 11:20 AM
boyo's Avatar
Yup, I've got this on my '72 911T. I'm told this is a "stock" setup or at least vintage. Definitely a VW system. Looks just like mine, except yours is in better shape.
I didn't think there was a fan there. Or maybe I've just identified what the loose wire hanging down from that area USED to be connected to....!?
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '72 Porsche 911T
Old 08-07-2002, 11:26 AM
I think the rear mounted condensor was installed by the 2nd PO when the oversized deck lid condensor was installed. The car was located in Dallas so I think the owner went through some effort to make the AC work. I'm just getting ready to top it off with R-12. The system has gas in it but not enough to produce a cooling effect.
Yeah, you can definately hear the fan!
John Adams
1980 ROW 911SC
Old 08-07-2002, 12:01 PM
Wow, you don't see many of those!! I have the exact same condenser in my car, which is a '78 Euro SC. Is your A/C system underdash?
It's a smart piece of engineering they did on these systems, routing the refrigerant line to the fan cooled condenser first, so the lid mounted condenser runs cooler to ultimately keep engine temps down.
Michael
'98 Boxster in Ocean Jade Metallic
Old 08-08-2002, 10:04 AM
911longhorn's Avatar
I think I saw something like that advertised by Griffiths but it doesn't look like that. Their's is much bigger from what I recall.
1989 Carrera
Hookem Horns!
Old 08-08-2002, 10:52 AM
SeaDweller
I do not have an underdash unit. It makes sense to reject as much heat as you can in the primary condenser. Is the A/C system on your car working? I'm planning to top mine off with R-12 tonight. I'm keeping my fingers crossed.
John Adams
1980 ROW 911SC
Old 08-08-2002, 01:12 PM
Mark Wilson
Guest
Posts: n/a
Could a condensor from some other kind of car be fitted in to that space? I'm sure that Griffeth's is a nice unit, but pretty expensive.
Mark
Old 08-08-2002, 03:27 PM
I charged the A/C system tonight with 12 oz. of precious R-12. I'm running around 33 psig suction pressure. The sight glass at the reciever still has a few bubbles but everything is working and I've got nice cool air out of the vents.
John Adams
1980 ROW 911SC
Old 08-08-2002, 05:54 PM
