Dave Kost's Avatar
Compression and leak down test question?
Can you do a compression and leak down on a non running engine that is out of the car? If so, are the numbers accurate?
Dave K
Old 08-26-2013, 08:39 AM
E Sully's Avatar
I do a leakdown on freshly rebuilt engines before installing, and again after break in. OCD. I know the numbers will be low slightly low before breaking the engine in, but it gives a quick indication if a ring or valve is not right. Much easier than installing and then having to drop the engine if the numbers are bad. It's also easier to actually hear where the air is leaking out from.
Ed
1973.5 T
Old 08-26-2013, 11:05 AM
Dave Kost's Avatar
Ed thanks for the reply.
My situation is that I may buy a engine without much documented history and want to do a leak down. Knowing that there could be other issues would the leak down/ compression results be accurate if done by cranking the engine by hand with all the plugs out?
Any other recommendations before purchasing the engine?
Dave K
Old 08-26-2013, 11:21 AM
Home of the Whopper
Crank the engine by hand to do a compression test? Please video and post results.
A cold leakdown should tell you enough. If all numbers are close and not too high, should be a decent engine.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 08-26-2013, 12:11 PM
Platinum Member
dad911's Avatar
You can do a leakdown, but not compression if the engine is out of the car. You would need to crank with a starter for compression test.
What year/size engine?
You can pull valve covers and check head studs.
Old 08-26-2013, 12:57 PM
Dave Kost's Avatar
2.7 rebuilt 40k ago
head studs replaced
higher compression pistons
chain tensioners
Pop off
engine looks clean
no docs but I can contact previous previous owner
Dave K
Old 08-26-2013, 02:14 PM
A battery, jumper cables to the starter and a battery operated compressor or portable air tank (i.e. if an AC powered compressor is not available) will allow you to do all the tests you desire.
Old 08-26-2013, 02:50 PM
Dave Kost's Avatar
I wore my arm out cranking ..... But I got 165 psi across the board!
Old 08-29-2013, 12:34 PM
Guardsred911's Avatar
seems like a good outcome.....
J
911 SC - 1980
911 S - 1977
Old 08-29-2013, 05:53 PM
