-   -   Engine drop support areas (http://forums.pelicanparts.com/porsche-911-technical-forum/767914-engine-drop-support-areas.html)
spooldup 08-26-2013 09:16 AM
Hi pelican techs, first time dropping the motor out of my race car. I have done street 911 motors before & my headers are already off to be jet hot coated. My question is, does anyone have a pic of where they supported the engine without having to do the balancing act on the center case spines? I was thinking of cutting a V in a block of wood and some kind of outriggers at the heads/valve covers strictly for support not to actually take any of the load. My engine does not have the flat round sump plate so working with the case spine is all I have to work with. Thanks for any suggestions before I hit the lumber yard.
vash 08-26-2013 11:55 AM
a furniture rolling dolly works decent.
i made one that straddled the exhaust. it finally broke after about 12 drops. i kept the wheels to make another if needed. my jack pushes the dolly up agains the motor, and i simply lower it onto the rolling caster wheels. pull out the jack and roll out the motor.
http://forums.pelicanparts.com/uploa...1377543267.jpg
wildcat077 08-26-2013 12:40 PM
Make yourself a wooden dolly,a couple 2x4's,wood screws and four casters ...
Cheers
Phil
http://forums.pelicanparts.com/uploa...1377545813.jpg
http://forums.pelicanparts.com/uploa...1377546025.jpg
spooldup 08-26-2013 01:41 PM
Thanks guys, that's pretty much the direction I was headed just wanted reassured. Also, I forgot to mention it is a twin plug motor I have for the first time too.
wildcat077 08-26-2013 02:07 PM
I had made the dolly two years ago when the clutch in my 3.2 exploded and i used it as well a few months ago when i installed my 3.6,basically the same thing,although the 3.6 had more lower engine tin to worry about !
Cheers
Phil
rusnak 08-26-2013 02:10 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/401955-supporting-engine-removal.html
theclaw 08-26-2013 03:20 PM
Cheers
Phil
I like the special "Renndolly". Custom. Nice.:)
theclaw 08-26-2013 07:59 PM
If I'm using a jack and some type of dolly, where is the center of the engine weight if the transmission is still mounted. I got mine down, but I didn't like the HF lift i used and will likely return it. If i just build my own "Renndolly" how far back from the front do you place the jack to balance it all the way Vash has done?
Costa P 08-26-2013 09:04 PM
Here is what I came up with.
http://forums.pelicanparts.com/porsche-911-technical-forum/401955-supporting-engine-removal-5.html#post6962011
spooldup 08-27-2013 11:37 AM
All great ideas & pics and hope to build this tonight, thought I would show a pic of my car too. The front bumper with red tape goes to my painter once the motor & trans are out. As noted in original post, it's my first drop on my race car which is different than having heat exchangers to rely on when I did my street cars.http://forums.pelicanparts.com/uploa...1377628600.jpg
wildcat077 08-27-2013 12:55 PM
Wow ... that is nice !
I'll be going wide body with mine soon ... the search is on for fenders and flares !!!
Cheers
Phil
JJ 911SC 08-27-2013 04:53 PM
Cheers
Phil
Phil
How is your line of credit doing??? ;)
wildcat077 08-27-2013 06:05 PM
My bank considers me a very good customer !!!
JJ,how much could a couple fenders and some flares cost ...
I have an awesome painter,i'll send you some pics of the bumpers and rear wing he did ... does it match ??? once it gets pummeled with flying rubber debris and bug juice it'll blend in just fine :)
You know me,i'm not a "wash my car" type of guy anyways ... lol
Cheers
Phil
