Engine drop support areas
Hi pelican techs, first time dropping the motor out of my race car. I have done street 911 motors before & my headers are already off to be jet hot coated. My question is, does anyone have a pic of where they supported the engine without having to do the balancing act on the center case spines? I was thinking of cutting a V in a block of wood and some kind of outriggers at the heads/valve covers strictly for support not to actually take any of the load. My engine does not have the flat round sump plate so working with the case spine is all I have to work with. Thanks for any suggestions before I hit the lumber yard.
Old 08-26-2013, 09:16 AM
vash's Avatar
a furniture rolling dolly works decent.
i made one that straddled the exhaust. it finally broke after about 12 drops. i kept the wheels to make another if needed. my jack pushes the dolly up agains the motor, and i simply lower it onto the rolling caster wheels. pull out the jack and roll out the motor.
poof! gone
Old 08-26-2013, 11:55 AM
Northern Motorhead
wildcat077's Avatar
Make yourself a wooden dolly,a couple 2x4's,wood screws and four casters ...
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-26-2013, 12:40 PM
Thanks guys, that's pretty much the direction I was headed just wanted reassured. Also, I forgot to mention it is a twin plug motor I have for the first time too.
Old 08-26-2013, 01:41 PM
Northern Motorhead
wildcat077's Avatar
I had made the dolly two years ago when the clutch in my 3.2 exploded and i used it as well a few months ago when i installed my 3.6,basically the same thing,although the 3.6 had more lower engine tin to worry about !
Cheers
Phil
Cheers
Phil
Old 08-26-2013, 02:07 PM
supporting engine at removal
Old 08-26-2013, 02:10 PM
theclaw's Avatar
Cheers
Phil
I like the special "Renndolly". Custom. Nice.
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 08-26-2013, 03:20 PM
theclaw's Avatar
If I'm using a jack and some type of dolly, where is the center of the engine weight if the transmission is still mounted. I got mine down, but I didn't like the HF lift i used and will likely return it. If i just build my own "Renndolly" how far back from the front do you place the jack to balance it all the way Vash has done?
'67 MB 250SL
Old 08-26-2013, 07:59 PM
Slippery slope skier
Costa P's Avatar
Here is what I came up with.
'85 930 ...the oil leak rebuild which mutated into more than I could chew... then came back to my senses and climbed "back up" the slippery slope!
A stock 930 is far better than an incomplete project car!
930 rebuild – The revival of my mothballed project
Old 08-26-2013, 09:04 PM
All great ideas & pics and hope to build this tonight, thought I would show a pic of my car too. The front bumper with red tape goes to my painter once the motor & trans are out. As noted in original post, it's my first drop on my race car which is different than having heat exchangers to rely on when I did my street cars.
Old 08-27-2013, 11:37 AM
Northern Motorhead
wildcat077's Avatar
Wow ... that is nice !
I'll be going wide body with mine soon ... the search is on for fenders and flares !!!
Cheers
Phil
Cheers
Phil
Old 08-27-2013, 12:55 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Cheers
Phil
Phil
How is your line of credit doing???
Who Will Live... Will See
Old 08-27-2013, 04:53 PM
Northern Motorhead
wildcat077's Avatar
My bank considers me a very good customer !!!
JJ,how much could a couple fenders and some flares cost ...
I have an awesome painter,i'll send you some pics of the bumpers and rear wing he did ... does it match ??? once it gets pummeled with flying rubber debris and bug juice it'll blend in just fine
You know me,i'm not a "wash my car" type of guy anyways ... lol
Cheers
Phil
Cheers
Phil
Old 08-27-2013, 06:05 PM
