fresh re-build won't start
Hi, I built a 3.2 short stroke with webers and an electromotive hpv ignition. i got it running with no leaks, idled fine but not tuned. so i finished other issues with the car and now am trying to start it again and it flat out will not start - nothing changed. i checked the fuel pressure (3.5 psi) ignition is firing. as the starter turns the engine over it sounds like it will catch at any moment but never does - any ideas?
thanks!
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
Greetings,
The HPV-1 manual is online and here is an excerpt directly related to your issue. HPV-1 Installation Manual 22 TROUBLESHOOTING GUIDE This Troubleshooting guide was written to help you diagnose any problems you might have with your HPV-1. ENGINE CRANKS BUT WON’T START OR FIRE Check: Supply voltage. With the ignition switch on, measure the voltages at the red and black wires that power and ground the HPV-1. Recheck while cranking. Red Wire Key on - 12.0 to 18.0 Volts; Cranking - no less than 10 Volts Black Wire 0.0 Volts under all conditions Check: Spark. The preferred method: Attach an inductive timing light to any sparkplug wire and crank the engine to see if the timing light strobes. Also, look for the tach needle to jump while cranking. Alternatively, use a sparkplug style tester and check for spark at the plug end of the wire while cranking. CAUTION: This is an extremely powerful ignition and may be lethal! DO NOT handle the spark plug wires or coils while the engine is running! STAY AWAY from all connections when cranking! Check: The magnetic sensor. Inspect for physical damage caused by the trigger wheel. Check the air gap between the sensor tip and wheel. Try smaller air gaps. Replace the magnetic sensor if the resistance between the red and black wires going into the sensor is outside of the 600 to 800 OHM range. Make sure the bracket and nearby parts are not magnetic or magnetized PS: I have used Megasquirt quite a few times now and have found that I often run the battery down, during tuning....it also has a 10V minimum level that must be maintained for proper operation. regards, Al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 09-01-2013 at 01:44 PM.. |
That might be it, I will check the voltage tomorrow. Thanks Al
Are the carbs leaking down the throats due to float level issues?
Porsche, aucune comparaison |
