930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Wheres ground for pass wndw mtr?
Pass window motor is sluggish and was gonna try to clean ground before I purchase motor. Wiring diagram doesnt show a point and I dont fell like tearing the whol car apart. Thanks
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-02-2013, 06:48 AM
Fleabit peanut monkey
Bob Kontak's Avatar
For years I was absolutely certain my window motor was on the way out. Darned thing never died, though. Would go faster with a fresh charge and slower if it had been sitting.
After ignoring about eight thousand posts about lubing the gearing, I had the door panel off and put a little fancy teflon lube on the gears and in the tracks. Not much at all. Problem fixed.
Search for for the right type of lube and you will be amazed. I would think most anything would be sufficient but you know there is the "correct" stuff mentioned somewhere.
1981 911SC Targa
Old 09-02-2013, 12:23 PM
The ground is in the trunk. There is about 5 wires in the main harness that have a large eye and grounded to a stud that is welded to the body. There are two of these ground points; 1 on the passenger side and 1 on the driver side.
The previous poster is more likely correct as the passenger side motor wears out much more often than the driver side and this is from "Lack of use". The grease dries up on the passenger side faster because the driver side gets used all the time.
Old 09-02-2013, 12:37 PM
h20cooled7's Avatar
Thank You Very Much! I will tear into both doors and lube up gears and assembly!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-02-2013, 02:22 PM
Bob Kontak's Avatar
One side at a time. You may need to look at the other to get the first back together correctly. :-)
Mark your wire colors and terminal numbers on the window switches before pulling them off.
Take your time. You will need a allen wrench. I think 5 or 5.5mm.
1981 911SC Targa
Old 09-02-2013, 02:39 PM
