Serial / transmission number question
A friend of mine is looking at purchasing a 911 transmission off of Ebay and has asked me if I can identify the following:
Up for auction is this 915 tranmisssion out of an 80's 911. Numbers on the trans are 915/63 1274D4832 He would like to know (if possible) what year and any other information you can tell from this number. He is also looking at another one with the serial (7102633). He is sure this is from a 1971 but doesn't know what the other numbers mean. Any help is appreciated.
Mark 1988 Black on Black coupe |
the 915/63 signifies that it is for a 3.0. which has an aluminum case and I believe has higher gears. 915/61 is the magnesium case.
2000 MR2 spyder 2001 ford Escape |
There is an error in the serial number ... but he won't mind!
There are actually three number sequences there! It should read: '915/63' '12' '74D4832' It is a 1983 model 915, and the '12' indicated it has a factory-equipped ZF limited-slip differential!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
And, the other box, 7102633, breaks down as follows:
7 = 6-Cylinder Car 1 = Transmission type 1, 5-speed, standard ratios 0 = Model year 1970 2633 = Sequential Number If the ratios have not been changed, they should be: 11:34 A 18:32 GA 23:28 O 27:25 V 29:22 ZA and the Ring and pinion should be a 7:31 There should also be a 911/01 stamped on the bottom case rib, ahead of the 7- number. Does it have a limited slip? Other useful information can be found here: http://www.911t.org/TechSpecs/number_codes.htm
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Early_S_Man or anyone else that may know. Is there a link to a site that provides the break down for the serial number that is on the transaxle for the 1980's 911's. A link similiar to the one that John_Cramer posted for 1970's 911's.
Thanks, Chris |
Is this the transaxle you guys are talking about with the lsd.
Yes, and he has already added info stating that it has the ZF ...
OK, so, who spilled the beans? Now that the price is going to rise significantly ... anyone seriously interested better email him and get verification that the output flanges can't be turned independently ... wiothout a great deal of torque being applied!
