Transmission cooler leaking
85 911
915 transmission
The oil cooler is leaking at the spot indicated. I have tightend the nut shown, but it is leaking above this spot, doesnt look like the flexible cooling hose is adjustable??
Ed.
Old 09-17-2012, 06:50 PM
Bill Verburg's Avatar
Originally Posted by strikee View Post
85 911
915 transmission
Ed.
There is a gasket under the cover
915.307.311.11
and there are o-rings on the cooler pipe
2x 900.174.033.40
Bill Verburg
Old 09-18-2012, 06:41 AM
Ah ok thanks Bill. So does the black cooler pipe disconnect from the sheet metal part so you can get the o-ring in? Unscrews I guess.
Old 09-18-2012, 03:43 PM
Peter Zimmermann's Avatar
The cooler tubes (in/out) each have an o-ring. They simply push in/pull out, and each is held with a small bracket.
Keep the Shiny Side UP!
Pete Z.
Old 09-18-2012, 03:56 PM
Is there a code that superceded the O-ring for the cooler pipe?
nothing shows up under 900.174.033.40
Old 06-12-2014, 02:53 PM
Not according to the Jan 2010 version of PET
You need to be looking where they list RoW parts, a US only version won't have that part
Bill Verburg
Old 06-12-2014, 04:20 PM
Ah yeh, you're dead right. Thanks!
Old 06-13-2014, 12:32 AM
