JED
ARCSinAK's Avatar
Boge Struts best option for replacement inserts?
I have a 74 Targa and the front and rear shocks are totally toast. Wanted some thoughts on the best replacement options. I see that both Bilstein and Koni make replacement inserts for Boge Struts. Anyone care to offer a opinion on which route to go. Sport of Standard? Keeping the front and rear same brand style. Do people often adjust the Koni's or just run a setting and leave them alone. I looking for a performance street set up.
Thanks for your thoughts.
Old 09-05-2013, 08:26 PM
HarryD's Avatar
At Steve Weiners recommendation I installed Bilstein HD struts and sport rears. They work great.
Old 09-05-2013, 09:32 PM
lonewolf's Avatar
Second the Bilstein HD front and sport rears
The adj konis are ok but you would probably end up running the fronts on full soft and the rears on hard
remember ,the harder the susp front and rear, the bigger and stickier the tires have to be and vice versa.
Old 09-05-2013, 09:51 PM
chapo's Avatar
I run the same front rear setup in a 69 912 vintage racer. Works good.
Patrick
Old 09-05-2013, 09:56 PM
a.k.a. G-man
Geronimo '74's Avatar
Same combo, love it!
Old 09-05-2013, 10:35 PM
JED
ARCSinAK's Avatar
Thanks for the feedback!
Old 09-06-2013, 12:15 AM
JED
ARCSinAK's Avatar
I see the rears part number 24-009751 offered in green and yellow is there a difference B/T these to color for the sports?
Old 09-06-2013, 12:58 AM
I think yellow are sports. I have a 73 Targa and for years ran the Koni adjustable red gas shocks, they were perfect. My rears started leaking so I installed Koni Sport adjustable rears. To hard for a Targa. I still have the red fronts. I don't know how the Bilstien compare to the Koni's but I would stay with the HD's front and rear, (Bilstien). The coupe can take a stiffer shock, the Targa needs a bit softer shock.
I wouldn't go wider than 6 and 7 on the wheels. New tire compounds are way stickier then they used to be so you don't need bigger tires unless you really increase HP.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 09-06-2013, 10:45 AM
HarryD's Avatar
I have no problems with my Bilstein Rear Sports in my Targa. Besides fun on the streets I regularly Autocross and DE the car. It has been lowered etc by Rothsport and the ride is fine (even to my wife who likes a cushy ride).
I have been told the Rear Sports are a bit shorter than the HD's and hence work well in a lowered car.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-06-2013, 11:32 AM
michael lang's Avatar
I installed Bilstein Sports in both the front and rear. When I did that several years ago, I was only doing autocross with only a dabbling of DEs but now exclusively track stuff and I love them. You'll find that the Sports will give you a very planted feel while driving. The one thing I would caution you on is be prepared to have the ride height readjusted after doing a shock upgrade because the new shocks will definitely raise the body of the car after being replaced.
Mike
'89 CARRERA
#402
Old 09-08-2013, 06:14 AM
