This is my extra dme. Now you have me curious.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 09-06-2013, 11:14 AM
Ops. Too late. I just saw the post. My thought here is to have this one looked over and then plug it in. Leaving the original one in the car. This came out of a donor car for another project. I may send it off at any rate to have it thoroughly inspected for future use.
Old 09-06-2013, 11:16 AM
Go-Kart Mozart
JAR0023's Avatar
Originally Posted by sundevil64 View Post
Anyone have a part # for the bmw or application I can look up?
Bosch 0261210002
Crank Reference/Speed sensor for BMW application. $60 each if you search the web. I have about 6k trouble free miles on a set. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 09-06-2013, 11:33 AM
Originally Posted by JAR0023 View Post
Bosch 0261210002
Thanks. It looks like the application is an 85 635is. $54 each.
Old 09-07-2013, 04:25 AM
scarceller's Avatar
Testing coil is easy.
1. remove '-' wire from coil's '-' terminal
2. turn key to RUN test that you have 12v on the '+' terminal
3. place a spark plug wire from the coil to a test spark plug on the end and ground the test plug. Do NOT go through the distributor, you want just one spark plug hung directly from the coil's hi-voltage output.
4. using a test wire, wire one end to the coils '-' terminal and then ground the other end for no more than 2 seconds, within 2 seconds remove he ground and the plug will fire.
Testing for DME coil pulses requires a simply LED test light. You can get one at Walmart for $5. It must be a a 12vdc LED test light. Then test DME for coil pulses like this:
1. Remove wire from '-' terminal on coil
2. Place test light's '-' to the wire you just disconnected.
3. Place test light's '+' to the coil's '+' post.
4. Crank engine and watch test light, it will flicker as the DME generates coil ground pulses.
Originally Posted by rick-l View Post
You did I missed it.
I missed that also.
Might not be time to tear into the DME. Can you think of a way to verify the DME signal at the coil and the coil itself?
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 09-09-2013, 01:17 PM
Thank you. I will try those.
John
Old 09-09-2013, 05:50 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
The speed sensor is the main timing device and the reference sensor is required to determine TDC. With an intermittent speed sensor your engine cuts out every time the signal fails. With an intermittent reference sensor you might fare better since it is not always required. It is used to correct timing every once in a while.
Both sensors can fail intermittently with age due to the heat cycling/vibration at the bell housing. Not easy to diagnose since you need to catch the failure "in the act" by having a breakout box with an O-scope. Probably a good idea to replace the sensor when in doubt before embarking on more expensive items.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 10-14-2013, 07:06 PM
Chain fence eating turbo
How many cars do you have, John?
Ingo and Sal are very well versed in these systems. You're in good hands. Just remembered, I have a new sensor in my toolbox if you need to buy one. Only used for testing.
Old 10-14-2013, 07:26 PM
Tippy,
Too many...
I ended of putting intwo new sensors, the BMW interchangeable one and it fired right up. I took it on a 400 mile drive without a related hitch. I only lost a mirror as if fell of while driving.
Old 10-14-2013, 08:41 PM
silver911rdb's Avatar
Quick question. I just measure the resistance on my reference/speed sensor in my 964. It measures approx 500 ohm. Manual says it should be 960 +/- 96 ohms. The motor fires up and sounds normal. I'm having an issue with the headers glowing (even at idle I see a faint glow). Infrared thermometer shows temps in the 750 range at idle. I've checked most everything trying to narrow down the problem. Would this sensor cause the headers to glow? I'm guessing maybe the ignition timing would be effected by this causing it to run too hot.
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 09-28-2014, 08:26 AM
