Need Help -Targa alignment pin cover...
I used my PCNA $100 off coupon this week on several items at my local Porsche dealership. Part of this purchase was for the 2 plastic covers on the targa top alignment pins that slide into the roll bar. Removal of the orginals was easy. Both were already cracked and chipped, so I slit them fully open with a utility knife and they came right off.
I thought the new covers would just slide onto the pins. ![]() The problem is with installing the new covers. The inside of the covers have "ribs" that appear to "engage" on the pins. I can press each of the covers on over the first few ribs, but no further. I'm hoping someone else on the board has performed this task and knows a trick that will work.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Mark,
Two things ... a bit of silicone grease on the pins close to the frame, and warm the covers in boiling water for a couple of minutes. Wear heavy leather gloves ... and work quickly! BTW ... what's wrong about this pic from the 1975 brochure? ![]()
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks Warren. I'll give it a try.
BTW: The pic is missing the parts I'm trying to install.
Marc,
That's because it is a pre-74 top ... no center alignment pin, and no plastic covers to suppress noise/rattles, either!
Warren,
You da man! One cup of water, super-hot from the microwave. Soak alignment pin covers for about 5 minutes. One small squirt of lube on the pins, and the covers slid on with no effort. ![]()
Another way that works is to use a hair dryer or heat gun, particularly if you have them partly on and can't get them off (ask me how I know!).
Just heat them and push right on. (I got this tip courtesy of Dan at Cars Inc.)
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
Had to take one that was stuck half way through with a box cutter, 15$ down the drain... Now I know. To be continued tomorrow.
1985 911 Targa (sold) 2001 996 Twin Turbo (sold) 2001 996 C4 |
And if the hot cover does not slip on completely use a heat gun to heat up both the pin and the cover. Work it down with a utility glove. Ask me how I know.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Thread Tools | |
Rate This Thread | |
