Post Alignment Questions
Recently installed turbo tie rods, new shocks and new tires onto my 1987 911. The tire shop did both the tires and the alignment. Now, the car steering is much easier than before and I am experiencing bump-steer that I never felt before. Has anyone experienced this after an alignment?
Old 09-15-2013, 09:33 PM
Sounds like you may not have enough caster, that will certainly cause the light steering feel, at the expense of straight line stability...
Chuck.H
'89 TurboLookTarga, 363k miles
Old 09-16-2013, 04:53 AM
Usually you get a printout after the alignment that tells the before and after specs.
Do you have it?
Old 09-16-2013, 07:04 PM
