Chain Ramps -- Suggestions/Questions!
Been on this same freaking chain ramp for 4 freaking hours!!!!! Driver side, lower in board. Can get everything lined up, but can't get the bleeding thing to snap on! I have stuffed screwdriver, pliers, bent screw drivers, bent pliers, fingers, bent fingers...but every time I ratchet down the in board bolt,.....same thing, the outboard pops off! I've tried running the stud in and out of the ramp while out of the car...I've tried grease, oil, you name it! Same thing!Frustration point is a bit high right now....open for suggestions before I get the sledge hammer. thanks
Rob Black 1983 911 SC Coupe Last edited by Erakad; 08-11-2002 at 07:27 AM.. |
Anyone???
Rob Black 1983 911 SC Coupe |
Two suggestions: 1. Change title to "Chain ramp won't fit" 2. Keep bumping yourself to the first page until John Walker logs back on. He'll know....
Formerly bb80sc
Erakad,
I ended up using a narrow block of wood and had it run between the top of the ramp and the back of the case. If I recall, I did the outboard bolt first, then the inner. I tied a piece of string to it in case I dropped it. I'd also recommend using a piece of string thru the bolt hole in the ramp so you do not lose it either Gotta remove it before putting the 2nd bolt in, tho.Also DO NOT in any way, shape or form move the chains. Please do not ask how I know this, I still feel the pain...... doh! Best of luck, I know it's frustrating.. cheers -Brad 80SC with new(er) engine |
I dont wanna sound stupid but you know one is different, are you sure you are putting the in the right place? Kevin
Like the idea of renaming the post and hoping for the best...frustrating afternoon, definitely on the bottom of my automotive experiences. Finally got the darn ramp on 2 hrs after my original post...one more question on that though....can there/should there be any play in the ramp at all? I noticed out of the car the ramp still had "wiggle" room on the bolt. Could this translate to the installed ramp? Not much movement, but it does move slightly.
Am really trying to be careful and not move the chain from the gear. On the parts I can see, I've wedged wood between the chain and the case, put a cable tie through the gear and chain next to the tensioner, painted marks across the gear and chain to the case and supported the chain well when removing and replacing the lower ramps. I plan on spinning the engine (manually, clockwise) at least 10 times (without sparkplugs) to check for binding....I'm really paranoid after the posts the last couple months! Will probably add more ties tomorrow... But as I said, I'm now concerned about the movement...should I pull it out again and reinstall Sighhhh....
bump
bump bump
