AutoBahned
RWebb's Avatar
List of Myths, Fairy Tales, Lies, & Common Misunderstandings
from Gunter:
"Revving an engine before shutdown is [a] myth."
"You have to come to a full stop before re-setting the Odometer"
"KN filters increase HP"
I'll add a few:
The original Dr. Porsche designed the 911.
Painting something white will affect infrared heat absorption or emittance.
Radiators cool the motor by radiating away heat.
Bigger brakes will always help you stop faster.
Old 01-05-2008, 03:28 PM
AutoBahned
RWebb's Avatar
A common myth, recently noted by Sherwood:
You should let your car idle for a while to warm up before driving it.
Sherwood pointed out that besides harm to the oil, this does nothing to warm any other fluid or component part.
Old 01-05-2008, 03:30 PM
Try not doing that with a 944 and you will discover it's not a myth.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-05-2008, 03:36 PM
LakeCleElum's Avatar
Myth = Don't charge a battery sitting on a concrete floor.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 01-05-2008, 03:37 PM
Won Won is offline
Won's Avatar
Depends on whether the gears inside one's odometer is 20+ years old and brittle as heck, I'd imagine? Or is it something particular to 944s? I broke my gear when I reset the trip meter while stationary. Put in a replacement gear and I can reset it at any speed I want
I have one, the credit goes to Wil Ferch:
- 911s are hand built cars, and as such the tolerances vary from car to car.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 01-05-2008, 05:06 PM
Registered Usurper
DARISC's Avatar
"Better gas mileage is achieved with windows rolled up and AC on than with windows rolled down and AC off."
What is AC?
'82 SC RoW coupe
Old 01-05-2008, 05:41 PM
if you try resetting while moving you can feel the gears being strained.
I've broken a few doing that. If I push it slow enough at low mph I could usually get away with it.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-05-2008, 05:53 PM
Todd Simpson's Avatar
"Oversteer is bad."
Old 01-05-2008, 05:56 PM
"You should let your car idle for a while to warm up before driving it."
as short a time as possible without lugging the engine.
I need CHT of around 140F so it's not spitting, coughing, and lurching during the winter. That takes a couple of minutes.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-05-2008, 05:57 PM
Non Compos Mentis
Loren will chime in any minute now to explain the myths of aftermarket chips........
Old 01-05-2008, 05:58 PM
I've charged them sitting in salt water.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-05-2008, 05:59 PM
Myth = A woman's reality doesn't change during her menstrual cycle.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-05-2008, 06:09 PM
Bill is Dead.
cashflyer's Avatar
A Porsche engine is a mystical thing, so precise in tolerances that it must be built in a clean room by white gloved technicians.
You cannot re-use alusil cylinders.
Old 01-05-2008, 06:17 PM
"you'll burn a valve if you have a hole in the exhaust."
"ya gotta keep the revs up real high or you'll overheat. it's aircooled ya know."
"you'll poke yer eye out!"
"don't use solvent or gasoline to purify a cut." hmmm, works for me.
206 637 4071
Old 01-05-2008, 06:29 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Originally Posted by Todd Simpson View Post
"Oversteer is bad."
Depends where you are in the turn
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 01-05-2008, 06:30 PM
Registered Usurper
DARISC's Avatar
911 oversteer will kill you.....
or make you giggle.
'82 SC RoW coupe
Old 01-05-2008, 06:41 PM
Chuck Moreland's Avatar
Wide tires put more rubber on the ground
Chuck Moreland - elephantracing.com - vonnen.com
Old 01-05-2008, 06:46 PM
Danny_Ocean's Avatar
"If you marry me, I'll do anything you want" = FALSE!
Old 01-05-2008, 07:04 PM
SCWDP911's Avatar
myth - fine women's leather boots are a great way to recover a steering wheel...
Shane
- 1984 928S
Old 01-05-2008, 07:22 PM
boxster03's Avatar
Herr Porsche was innocent in all things Third Reicht
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 01-05-2008, 07:40 PM
