nene's Avatar
Clack-clack-clack noise?
Recently, I have noticed that when starting my 86 Carrera from a cold start, I hear a clacking noise (which sounds like the valves) on the drivers side of the valve covers area. It appears that once the OIL hits that area, the sounds goes away (yikes)!! Any suggestions gents?
Thanx,
Old 09-13-2013, 09:03 AM
T77911S's Avatar
pull the valve cover and check it out. could also be a clogged hole in the spray bar
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-13-2013, 09:09 AM
nene's Avatar
Thanx, I will look into it once I dive in there to do the Valve Job!
Old 09-13-2013, 09:15 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Just talking here. Any change in oil viscosity from the heavier stuff the cars should use?
1981 911SC Targa
Old 09-13-2013, 02:39 PM
nene's Avatar
Bob, I did recently did and oil change, but I don't think it's too thick.
Old 09-13-2013, 08:43 PM
Bob Kontak's Avatar
New cars use pretty thin oil.
I don't know enough about oil to advise you. But if you did put oil in yourself and you don't know what the viscosity is, then you might want to replace it with the correct viscosity oil to be sure. That will cost you $75 or so with oil on sale as you probably know.
If you asked what you needed at the parts store and they told you, there is a very good chance it is fine.
1981 911SC Targa
Old 09-14-2013, 08:29 AM
Speed Dog's Chauffeur
Dodge Man's Avatar
Valve Adjust?
Since you have to drain the oil to do a proper valve adjust/inspection, you may want to at least see if the rockers have small jiggle(proper crank position required) to see of any valves are too tight. This can be done while you are inspecting the oil sprayers. Do you have start-up smoke? Best of luck.
Old 09-14-2013, 09:38 AM
nene's Avatar
Dodge, I do have some smoke on start up. Can loose or tight valves cause smoke (besides tired engine)?
Old 09-14-2013, 04:53 PM
Banned
Horizontally opposed cylinder engines smoke at startup even when brand spankin' new (it's the nature of the design and has nothing to do with valve lash settings).
Old 09-14-2013, 05:17 PM
Hunt3R's Avatar
My 3.2 over time had started to blow out a white cloud of smoke on cold starts and for the first couple minutes driving off down the road I could see faint black smoke coming around the car as I would slow down to idle at a stoplight. Then I did a valve adjustment and now there's absolutely no smoke at all, none at all when starting up and none at all at idle when warming up. Changed the way my engine sounds now too.
So I'm gonna say yes. And make sure you're using a thick weight oil too like a 20w50. What oil did you put in?
Old 09-14-2013, 06:08 PM
I have an 89. No smoke at startup or other times.
If the rockers, cam and valve stems are in reasonable shape and adjustment the sound at idle will be like a well oiled Singer sewing machine. Something like that, if you are hearing "clacking" you have some sort of issue. IMHO.
Sold: 1989 3.2 coupe, 112k miles
Old 09-14-2013, 06:24 PM
No smoke at 146K miles.......
My '89 Carrera with 146K miles does not smoke during cold starts. But my other '78 SC does. And my son's '87 Carrera does not either too. So with my Subaru Impreza.
Tony
Old 09-14-2013, 08:05 PM
lonewolf's Avatar
Clacking on startup can also be from low oil.
If you did a change recently and before you go taking everything apart make sure you have the proper amount of oil in the engine.
Old 09-14-2013, 08:22 PM
Bob Kontak's Avatar
Let's think about this for a little second.
The valves move up and down all the time in the valve guides the height of the lobe on the ol' bump stick. That can be measured in fractions of an inch - I don't know, a quarter or three eighths?
You adjusted them this way or that a very few thousandths of an inch in the same direction the cam moves the valve.
I am not seeing any reason why a valve adjustment could cause an improvement in oil seepage through the valve guides.
I am thinking you are merely in the cosmic grace period before the next fog. (See Ronnie's post)
Also, from my experience, blowing smoke on start up is a hit or miss thing. I can go for weeks, even months, with no smoke then it fogs the neighborhood. Like, I should go to jail smoke. Maybe it has to do with where the engine stops?
1981 911SC Targa
Old 09-14-2013, 08:55 PM
Banned
Bob, that is my experience with start-up smoke as well - no visible smoke for weeks, and out of no where, a juicy burst of it. I've experienced this with every opposed cylinder engine I've ever been around (including the Type IV in a 914 I drove for years, and the aircraft engines I've worked on). Of course, none of this with the glorious Opel lump!
Old 09-14-2013, 09:29 PM
nene's Avatar
I don't know boys, back in the high school days (1986 or so) I bought my first Porsche (yes in high school) a 1975 911s with 86k miles on it and that thing never smoked and it even had a broken stud (which I thought was a leaking exhaust). Now this car that I have (picture) mainly pumps out smoke on start-up and generally smell the stench when coming to an intersection or stop!
Old 09-14-2013, 09:36 PM
Bob Kontak's Avatar
LOL - For those that never owned an Opel GT like Ronnie and me......... If you have to ask you wouldn't understand.
1981 911SC Targa
Old 09-14-2013, 09:39 PM
nene's Avatar
Old 09-14-2013, 09:47 PM
lonewolf's Avatar
smoke on startup can also be caused by slow closing /sticky the odd time injector or another fuel source.
The tiny bit of fuel washes the cylinder and hence the smoke on startup.
That's why it only happens every now and then .
also if say you started the car but only let run a few secs to maybe check something and then it was off for couple days . it could smoke on startup for a few secs.
As an old pro engine builder told me many years ago ,if it doesn't happen all the time .dont worry about it.
Old 09-14-2013, 10:55 PM
Banned
Sorry, but this is not at all accurate. It takes far more than a "tiny" amount of fuel to result in cylinder washing (more like a grossly rich running condition, or a water/methanol injection system that is not working properly) and if oil was washed from the cylinder(s) when the engine was not running, then there would be no oil there to burn when the engine is started, and therefor, no startup smoke. The reason that the startup smoke is intermittent is that, due to the cylinder layout, "sometimes" oil, enough to result in visible smoke, travels past the rings, and into the combustion chamber, when the engine is not running.
Old 09-14-2013, 11:18 PM
