| Registered |
				Engine "missing"  - spark or fuel?
			Here's the situation,  My 1985 Carrera 3.2 is starting to have an issue.  It has 97,000 miles on the odometer.  I purchased about a year ago with 93k.  Previous owner only drove it about 500 per year.  He took very good care of it. The P.O had a major service in 2012 (valves, fuel filter, etc.).  About 6 months ago I noticed a very slight, almost unnoticeable. "miss" or power loss in the mid range under hard acceleration.  Over the past 3 weeks or so it has gotten considerably worse.  She starts and idles just fine and it is not present under normal driving, just when I get hard on the gas.  It starts at about 3500 rpm and higher, and it is on and off miss not a gradual loss of power, but eventually catches up and runs good.  It's just in the mid-range. So is it a spark or fuel issue? | ||
|  10-27-2013, 02:25 PM |
| Registered Join Date: Oct 2006 Location: MYR S.C.
			yes. i can also add an air leak and even the crank position sensor.
				__________________ 86 930 94kmiles [_  _] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_  _] RUNNING: [__] NOT RUNNING: 01 suburban 330K:: [_  _] RUNNING: [__] NOT RUNNING: RACE CAR:: sold | ||
|  10-27-2013, 04:25 PM |
| Registered |
			Anyone else?
|  10-27-2013, 07:19 PM |
| Bad LT Join Date: Dec 2008 Location: Newcastle Australia
			Althought it could be a number of things I'd start with a couple of fuel filters. Cheap and easy enough to do.
				__________________ Ex Porsche Cup car with some boost and stuff. | ||
|  10-27-2013, 08:25 PM |
| Registered |
			an on and off miss is most likely ignition. if ignition, most likely the coil. I've had coils that ran perfectly at idle and easy acceleration. get on it harder and they'd miss. | ||
|  10-27-2013, 09:23 PM |
| Registered Join Date: Jul 2008 Location: Spokane WA
			Agree that I would start with a new fuel filter. Also plug wires can get old and cause issues. Clewett makes a nice set that's less expensive than stock.
|  10-27-2013, 09:31 PM |
| Registered |
			Hot engine miss under load points toward secondary ignition. Try spraying spark plug wires (spark plug cavities) with a pump bottle to eliminate HT wires. Spark plugs should be renewed too.
				__________________ Porsche, aucune comparaison | ||
|  10-28-2013, 04:31 AM |
| Registered Join Date: Feb 2006 Location: Ontario Canada
			missing under load could definitely be plugs . You said it was done but start with the basics, dont take any ones word for anything.  Also remember under full load the fuel pump could be considered a possibility also. Personally i would: 1. Replace plugs 2. Run at night and peer in to see if i have any spark leak 3. Swap coil ( only real way to tell ) 4. Fuel Filter 5. Verify CHT is two wire sensor and replace it if it isnt 6. Put in your spare DME relay just to elimintate a good start i would think ..
				__________________ 1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) | ||
|  10-28-2013, 06:04 AM |
| Registered |
			And don't discount the speed sensor - even though it usually is an RPM range more so than a load range where it fails intermittently.
				__________________ 1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 | ||
|  10-28-2013, 09:31 AM |
| Registered |
			Thanks for the suggestions.  Plugs picked up today and the hunt begins...
|  10-28-2013, 07:00 PM |
| Registered |
			Check the air flow meter contacts inside the box. At high mileage the copper arm almost wears out the contact strip. You can reposition it to have proper resistance throughout the range .
				__________________ 1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera Last edited by kodioneill; 10-31-2013 at 06:17 AM.. | ||
|  10-31-2013, 06:14 AM |
| Registered Join Date: Dec 1999 Location: Novato, CA
			It could be as simple as a plug connector that came loose. Might be worth checking.
|  10-31-2013, 11:39 AM |
| Registered |
			So I thought I post a follow-up message. Well after purchasing a new CHT sensor and Oxygen sensor I was in the garage preparing to install and my Dad happened by. He says "why don't you start simple and try some fuel injector cleaner?" Ha! I scoffed and said it couldn't be that easy. But with certainly a few hours of work in front of me I decided to try it. I bought Lucas injector cleaner and Viola' problem solved. It literally only took about a 3 blocks of driving and all surging/missing ceased. Moral of the story...start simple.
|  11-10-2013, 04:58 PM |
