Removing windshield and rear window trim
I have found that a PVC pipe cutter cable saw is the best way to get the trim out of window rubber trim. Gently pry up a center connector, slip the cable under and saw away around the window. Trim pops out perfectly.
Tru6 Restoration & Design |
Great idea thanks. Tim
Uncertifiable!!!
Shaun,
Did you need to lube as well? Thanks for sharing. Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Hey Johan,
No lube needed, a light sawing action lifts the embedded channel out of the rubber molding if it's resistant to change.
Perfect solution. Thanks for sharing it.
I use the same technique using a long exact knife. I cut the seal clean through to the other side not disturbing the trim. -Thickest part of the seal remains on the car. -The slice of rubber that you cut away from the main seal still holds the trim and can be lifted away from the car. -the rubber that remains with the trim is so thin it easily will peal away without having to bend the trim. It is a great technique. I hadn't thought of using a PVC pipe cutter cable saw. Thanks for the tip Shaun Wayne
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
1980 911 SC
Nice job.
Life's a Beach |
