Shaun @ Tru6's Avatar
Removing windshield and rear window trim
I have found that a PVC pipe cutter cable saw is the best way to get the trim out of window rubber trim. Gently pry up a center connector, slip the cable under and saw away around the window. Trim pops out perfectly.
Tru6 Restoration & Design
Old 10-03-2015, 05:48 PM
Great idea thanks. Tim
Old 10-03-2015, 06:28 PM
Uncertifiable!!!
Uwon's Avatar
Shaun,
Did you need to lube as well?
Thanks for sharing.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 10-04-2015, 06:30 AM
Hey Johan,
No lube needed, a light sawing action lifts the embedded channel out of the rubber molding if it's resistant to change.
Old 10-04-2015, 08:26 AM
wayner's Avatar
Perfect solution. Thanks for sharing it.
I use the same technique using a long exact knife.
I cut the seal clean through to the other side not disturbing the trim.
-Thickest part of the seal remains on the car.
-The slice of rubber that you cut away from the main seal still holds the trim and can be lifted away from the car.
-the rubber that remains with the trim is so thin it easily will peal away without having to bend the trim.
It is a great technique. I hadn't thought of using a PVC pipe cutter cable saw.
Thanks for the tip Shaun
Wayne
SOLD - 914 wide body hot rod
Old 10-04-2015, 09:14 AM
1980 911 SC
Nice job.
Life's a Beach
Old 10-04-2015, 10:28 AM
