Ferrino's Avatar
Missing Torsion Bar/Control Arm Part?
Is the part identified in red in the following image common to all torsion-bar 911s? When I tore down the front suspension on my '76 911, I did not have this part - just the front control arm cover that has the tow-hitch on it. Where is it supposed to live? Thanks.
Old 09-18-2013, 11:59 AM
Those two pieces look familiar but I don't seem to have them anymore - perhaps they hold the pan that covers the fuel pump and steering rack? I don't use this pan anymore, that's why I'm thinking I removed them from my car.
They look like they may fit over the ends of the aluminum torsion bar support bracket.
Chuck.H
'89 TurboLookTarga, 363k miles
Old 09-18-2013, 01:14 PM
AutoBahned
RWebb's Avatar
they fit over the front & protect the bars, etc. - should be cheap used; check the PET
Old 09-18-2013, 01:18 PM
Ferrino's Avatar
So the part circled in red sits between the front control arm bushing housing and the tow-hook cover?
Old 09-18-2013, 03:46 PM
See photo below for placement. I think the tow hook just uses the same 3 bolt attachments, but you need slightly longer bolts.
Car is a 72E in the photo
Mick
Old 09-19-2013, 01:36 PM
