aircooled addict
jimbeaux911's Avatar
Fuel pump issue
anyone ever experience a fuel pump working, then not.
I just installed a brand new one, it worked fine for a few days, then stopped. I installed another one, same deal.
It is on a 79 CIS, with no lambda and no DME.
any suggestions especailly from experience are greatly appreciated!
Jim
someday I will actually get to drive a 911
Old 06-04-2016, 04:20 PM
ROW '78 911 Targa
timmy2's Avatar
Ask Gary (username Wew) he just had the exact same thing happen, 3rd one going ok so far...
Not a lot of quality these days...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-04-2016, 04:32 PM
aircooled addict
wow that stinks to think its just bad fuel pumps.
Old 06-04-2016, 05:00 PM
Smile
similar thing on my the sc my brilliant mechanic 40 year p man tracked down my same problem after a recent rebuild... fuel pump shuts by three things the over rev limiter at 7 g and the car alarm forget the other reason, my issue was the car alarm a previous bad attempt at a removal disconnect sign was the plug in the drivers door should have been a key switch was plugged fix was remove the ground from the fuel pump relay cut it off flush knew it was the fix when the relay is pushed in and small stub of the ground made contact the fuel pump shuts off long shot but it got me running haven't had an issue since good luck let me know if this was any help
Old 06-04-2016, 05:28 PM
ROW '78 911 Targa
timmy2's Avatar
Wew had bad pumps as bench tested upon removal....
Dennis
Old 06-04-2016, 05:58 PM
Old 06-04-2016, 07:08 PM
this picture is with the relay still in the plug pulled out enough to view the ground peg cut off this small stub when pushed into the plug and contact is made will shut the fuel pump when the bad ground activates the alarm can't find the reason for the alarm being activated so the ability to shut down the car is stopped by removing this ground I can send more pics if this is not clear enough
Old 06-04-2016, 07:16 PM
I'm on my third pump when it arrives. I put in a new dansk tank. I am thinking it was the absence of the strainer but maybe the pumps are just bad. I bought the car which was sitting for eight years and had to replace the tank. It's frustrating that the newest parts a re the failure. I just bought a 100 micron filter to put in line to hopefully solve issue. I'd hate to think all the pumps are junk! I just refinished my wheels and I just want to drive this thing!
Old 06-04-2016, 08:33 PM
Pictures of new FP..........
Guys,
Could you post some pictures of these problematic FP's? Were these Bosch brand made where? I've been running my CIS bench tester using an old Bosch FP for many years now and heavily depended on a good reliable FP. So if we could identify this particular batch of FP, people would be saving time and money from not using them.
This case is very similar to the Brazilian made ignition coil. It looks great but does not perform like the old black ignition coil made in Germany. Thanks.
Tony
Old 06-05-2016, 02:48 AM
aircooled addict
I dont think my issue is the alarm system, as I dont have one. but perhaps I do need to run thru the wiring of the fuel system to check for any bad grounds as you suggest! thanks!
I will post some pics of the brand new fuel pumps that have failed as soon as I can.
ngrich99 its odd , cuz I just installed a new tank as well, perhaps there is trash in the new tank that is washing out with the gas and screwing with the pump?
Old 06-05-2016, 05:13 AM
Fahren mit dem Wind.
mhackney's Avatar
The FP in my 83 cabriolet finally gave up the ghost in Nov last year. Symptoms first presented as random "no start" issues, especially when warm after a drive. Continued to get worse and an obvious rattling noise. I replaced it with a Bosch 69466 purchased from Amazon. I'm sorry I didn't take a photo of the box and manufacturer info. I am going to do that as part of my records from now on. But, this pump has been going strong and I recently tested fuel pressures as part of some COS debugging.
I kept my old pump to have it rebuilt at some point. It looked like it was original. I cleaned the terminals and treated them with Gibbs to minimize corrosion. The terminals were really corroded, could be the source of your problems if you didn't thoroughly clean them.
I have a question though, are the rubber boots or an acceptable replacement available anywhere? I searched and didn't find anything.
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net)
Caregiver to:
1983 911 SC Cabriolet - Fahern mit dem Wind.
(Moss Green Metallic over Champagne and Brown Leather)
Old 06-05-2016, 06:19 AM
Talking try the relay
"fuel system to check for any bad grounds as you suggest"
this is how I started on the issue the pump would shut off while driving down the road fuel tank out and cleaned new pump waiting to install with the tank out I could easily access the pump checking the pump leads to find out if it was the power or the ground went through the fuse panel and cleaned up all the connections new connectors new fuses new wire on the tester key on it had power reinstall 2 miles down the road shut off called the pro had it towed fixed in 1 hour my car does not have a alarm either but whatever alarm that remained and wasn't removed caused the fuel pump power to ground out and shut it off easy test get a spare relay cut the ground try it or part it out it may not run again send some pics I am looking fix it man fix it
Old 06-05-2016, 07:45 AM
aircooled addict
well today I removed the new fuel pump, and it like the previos new fuel pump is dead. so I am going with faulty fuel pumps as my most likely issue. forgot to take a pic, but will. Im starting to think this car is cursed. LOL
Old 06-05-2016, 04:05 PM
ROW '78 911 Targa
timmy2's Avatar
Where are you getting the pumps?
FLAPS?
Maybe send the original out to be rebuilt if you still have it.
Dennis
Old 06-05-2016, 04:50 PM
First Bosch replacement locked up. Once out of car I reversed polarity and it started working. There was some metal slivers in the fuel that came out. I ran it on the bench and it seemed a bit loud and I didn't trust it so I sent it back. I flushed the new dansk tank again with 15 gallons of fuel. The second pump was quite on first install and I went for a short drive. I had approx. 7 gallons in the tank. I did a 180 to go back up the test track, I got about 100yds and dead never to restart. This pump when removed is locked solid and even on reverse polarity just clicks.
So I will plumb this 100 micron filter in and try again.
Old 06-06-2016, 06:35 PM
aircooled addict
the pumps I have been having issues with are the bosch ones as well. I said Id post a pic so here it is.
NGrinch where did you get the filter? Also if you can, post a pic with it installed, as there is not much room up there, id like to see how you did it.
THanks!
Jim
Old 06-12-2016, 05:56 PM
83 911SC Cab
Cherry Bomb's Avatar
I just purchased new Bosch from host. I sure hope they aren't all crap. Mine won't be on the road anytime soon.
Old 06-12-2016, 10:23 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Just keep the receipt handy, re-check before the 2 year anniversary. Swap if it starts making a loud buzzing sound. Mine started just after the 2 year period. Sending out for a rebuild. Suspect is the armature.
'85 Carrera Targa
PCA/POC
Old 06-12-2016, 10:33 PM
i installed an airtex from autozone 2 yrs ago, works fine
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 06-13-2016, 01:24 AM
FP rebuild place.......
Jim,
Where do you send them for rebuild? More or less how much $$$ per pump? I got a small box of dead Bosch FP's in my storage that I have been saving. Did not realize these are rebuildable (?). Thanks.
Tony
Old 06-13-2016, 04:05 AM
