Poll: Which tire size?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Poll Options
Which tire size?
wayner's Avatar
Help solving tire height dilemma
In the brand of tire that I am running,
my 275/40 rears are 25.62 tall
The options for the front are either 245/40 or 245/45 series
40 front = 24.71
45 front = 25.68
(current rear is 25.62)
The question is, if I limit my selection to just these two tires in this brand, which of the two sizes would you chose?
SOLD - 914 wide body hot rod
Old 09-18-2013, 05:42 AM
245/45.
Old 09-18-2013, 05:44 AM
IROC's Avatar
There's no reason to keep the front and rear diameters close. I don't see any advantage to the taller 45 series tire in the front (and the potential disadvantage of clearance issues and the taller sidewall having more flex/less stiffness). I would vote for the 245/40.
I ran 275/40-17s and 245/45-16s (24.68" diameter) for years...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-18-2013, 05:52 AM
wayner's Avatar
First two opinions and I am back where I started
Thanks for the input so far guys.
I've just added a poll to this thread.
Old 09-18-2013, 05:59 AM
Sboxin's Avatar
More information is needed to be helpful . . .
--- year of car (maybe 73 or other)
--- wheel size and offset
--- fender flairs or not -- Turbo?
--- spacers
We run 275/40/17 and 245/40/17 Hoosier R6 on 78SC stock fenders rolled
with 8" and 9" Kenesis wheels and have some rubbing on the inside -- you
can see car in my Garage photos
You will probably get 50/50 on your poll from this forum group
EDIT: OK I see your beautiful car - congrats on that !! IMHO of course, I would
use the 245/40 to keep a stiffer sidewall in the front . . .
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 09-18-2013, 11:29 AM
RETIRED
Joe Bob's Avatar
Not much 245/45/16 around to choose from. One maybe two street suppliers......sucks as that was my choice as well. None when I needed to replace....stuck with 50 series.
2012 ML350 3.0 Turbo Diesel
Old 09-18-2013, 11:40 AM
I think he's running 17 inch wheels on a wide body '73, so clearance shouldn't be an issue. Might even have anough horsepower to push these heavy things around.
JR
Old 09-18-2013, 12:00 PM
175K911's Avatar
How about adding a third choice in your poll:
3) It doesn't matter
If you're setting up a car after the tire installation, then it really doesn't matter. Personally most of the SC/Carrera racers are running 245/40 & 275/40 Hoosiers. Nobody runs 245/45 front
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 09-18-2013, 12:08 PM
wayner's Avatar
JR
Correct!
I'm replacing my existing 245 race rubber on the front with street rubber to match the new rears.
My dilemma is, given that both sizes fit fine and neither are the same diameter as the rear, which would you chose, slightly taller or slightly shorter?
It sounds like going with the 245/40s is the way to go from the comments, but 70% of the poll says 245/45
Old 09-18-2013, 05:21 PM
Had the same problem with my 83 SC.
Finally found 245/45/16 for my rear, Firestone of all places.
PRIMEWELL PZ900...........that right PRIMEWELL, I never heard of them either.
Did my homework and 20K later.......GREAT. Quite/smooth/wet-dry handling and holds on in the "D" curve to work every morning.
Old 12-10-2013, 07:04 AM
boss11's Avatar
personally I preffer the look of taller tire on the rear, i would go with 245/40
82 SC Targa Guards Red = Toy
04 E55 AMG Brilliant Silver = DD
04 Cayenne Turbo Platinum Grey on 22s = Previous DD
80 Wide body 12AT RX7 Black 350+ hp= Previous Toy
78 Alfa Romeo GTV Blue = My 1st Cool Car
Old 12-10-2013, 10:32 AM
wayner's Avatar
Thanks for everyones input on which 17" tire height would match best with my 17 rears.
My dilemma was to either go for a slightly taller or slightly shorter front.
My rears are 275/40/17
I solved this a while ago.
On the front I have gone with 245/40/17,
which is slightly shorter than the rear, rather than the 245/45/17 which is slightly taller than the rear.
Thanks everyone.
Old 12-10-2013, 10:35 AM
wayner's Avatar
Here is how it looks from the side with the 40s up front. Even though shorter, they look taller. I think that was the best decision.
Corner weighting will follow.
Old 12-10-2013, 10:58 AM
