Jocke's Avatar
Send a message via ICQ to Jocke
Idling problem 930 -77
I have done a searching in the forum but havenīt find any similar problem.
Yesterday when I would go for a little drive the engine didnīt start so I start checking both the fuel and ignition but I didnīt found anything wrong.
Little later I try to start it again and this time the engine just sparkling a little bit.... When engine finally running it was idling about 400 rpm, so I push a little on the gas-pedal and then itīs running OK.
A few hours later I start it up and the idle was nearly 2.000 rpm, after that I have check all vaccum-pipes (I think at least), but the problem still remain.
Could it have something to do with the earlier problem when it wont start?
I now it could be the W.U.R or something but I dont now how I checking that.
Please I need help real quick. (the summer is barely over here in Sweden)
"The car is a 930 -77"
Jocke
Jocke Andersson
Reach me on ICQ - 317860713
Porsche 930 -77 SOLD
Modified, one of a kind in Sweden.
Check out my car @: http://members.cardomain.com/jocke
Old 08-18-2002, 05:55 AM
Jocke's Avatar
If I start the engine without the Air-Box the engine idle as 900-1.000 rpm.
And I dont think itīs the Airfilter because if I take it off the idle is still running high, but as soon as I remove the hole Air-Box the idle is normal..
Strange...
/J
Jocke Andersson
Old 08-19-2002, 02:35 AM
