-   -   Do you blow cool your engine after a run? (http://forums.pelicanparts.com/porsche-911-technical-forum/772150-do-you-blow-cool-your-engine-after-run.html)
72doug2,2S 09-18-2013 02:37 PM
I just noticed the fan on the white Carrera from Brian's photo.
http://forums.pelicanparts.com/uploa...1379540142.jpg
http://forums.pelicanparts.com/uploa...1379540238.jpg
Arne2 09-18-2013 02:40 PM
No, not necessary for my uses.
Richwro1 09-18-2013 03:32 PM
I hate to admit it
manbridge 74 09-18-2013 03:35 PM
Nah... maybe if I was going to get my hands in there and wanted to cool off engine sooner.
Tspringer 09-18-2013 04:25 PM
Uhhhhhh NO.
My old hotrod '69 S - I ran 8-10 track events per year - 20-25 days per year for 5-6 years straight of flogging the thing as hard as can be done..... 7700rpm on a Supertec built 2.6L mag case with stock rods... and I never did so much as raise the lid after a session.
I did change the oil once a year or so. I also adjusted the valves. Once. In 5 years.
She was still running like a freight train when I sold her.
matt f 09-18-2013 04:36 PM
But I have used the engine heat to dry the inside of my helmet.
RWebb 09-18-2013 04:40 PM
I sometimes leave both garage doors open - does that count?
stlrj 09-18-2013 04:54 PM
That's what the eleven blade engine fan is for, isn't it?
Should we be fanning our water cooled cars too since the radiator fans shut off when the engine is turned off? I do notice a significant amount of heat radiating from the engine when I pop the hood.
sc_rufctr 09-18-2013 05:11 PM
After a drive I raise the engine lid once the car is back in the garage. Lets the heat out and not much else.
Cost nothing and it takes about 20 seconds to do.
M.D. Holloway 09-18-2013 05:33 PM
Let it cool naturally...
emac 09-18-2013 06:00 PM
At 63 I don't have enough breath left in me!
Ernie 81sc
Uncle 09-18-2013 06:01 PM
No, I'm a normal person.
SteamWolf 09-18-2013 06:05 PM
^ hahahaha
No. The engine has a perfectly good fan installed. A quiet lap around the block before shutting it down after a thrashing is enough.
Targa Me 09-18-2013 06:07 PM
I think the Porsche engineers took into account hot days and hot track days when they designed our cars.
No fan necessary. Me, on the other hand, will reach for a cold beer after a drive.
72doug2,2S 09-18-2013 06:50 PM
But it's funny, when I turn my motor off the fan stops cooling the engine. Do you think I have a defective 11 blade fan?????
I had a water cooled car whose fans actually continued to work on certain occasions for a few minutes after the engine was shut off.
The point is that Porsche designed a motor to cool the engine while in operation. Fresh cool air did the job. What I am concerned about is "heat soak." Once the cooling fan stops the temperature will rise. Will that cause damage, vapor lock, burnt oil, etc? I'm not sure, but I am one of the abnormal persons here.
I've read heat soak may increase your engine temp by "20 - 50 degrees hotter."
http://www.lotustalk.com/forums/f25/please-explain-heat-soak-50397/
Uncle 09-18-2013 07:33 PM
If your engine is not running you are not going to build any more heat. The fins on the cylinders will still be sheding heat without the fan running.
Blowing air over it will get rid of the hot air sitting around said cylinders no doubt but you need to ask yourself why are you shutting down your engine with out letting it cool down?
tazzieman 09-18-2013 07:51 PM
This has the potential to turn into a "hot flushes?" thread.
I too rely on the engine's fanny to keep it cool.
Some fair points raised , esp by Grady , in this old thread http://forums.pelicanparts.com/porsche-911-technical-forum/158227-engine-cool-down-procedure.html
ClickClickBoom 09-18-2013 07:52 PM
The best way to cool any engine is to run at a low power setting for a period of time. How long, depends on how hard it was run, racers take a cool down lap, I always go easy on the loud pedal starting about 5 minutes from shut down.
shbop 09-18-2013 11:36 PM
If you park in the garage, open the lid. Nothing like oven baking your hoses and electrics when you don't have to.
stlrj 09-19-2013 01:23 AM
My hoses are ovenproof (even hot oil proof), that's why they put them in my engine. Sorry to hear your hoses aren't. Maybe you could find some that are...
Best to keep your powder dry and your beer cold.
