There are tinned brass jumpers made for terminal blocks I use a lot in the industry. I'll take a look and see which ones fit the best for these next week some time.
Molex Incorporated - 38002-1478 - Terminal Block Accessories - Jumpers / Bridges - Allied Electronics http://forums.pelicanparts.com/uploa...1379743890.jpg |
Nice find Porwolf, exactly what I was talking about. (Except mine are squared off on top)
One other jumper option would be to file the insulation barriers and use a straight strip of copper with holes to fit the screws.
You made me look Don...:cool:
Just pop the segment off and connect them internally. They come off the base really easily with a small flat blade screwdriver. Each screw terminal segment then pops right out. May need to do a little fab work but it would be hidden... Very stealthy mod!:D http://forums.pelicanparts.com/uploa...1379746936.jpg |
Dennis
I have not found the way to put the jumper internally. The only way I was thinking is to put the straight jumper with holes and use nuts to hold it in place but it must be screwed after the cable is secured. The other concern to use this type of fuse block is the total amperage that it can handle as a whole unit. I remember somebody mentioned it in another post. |
30 amps per fuse, I posted it and a link to the manufacturer earlier at the bottom of the first page.
Just exploring options, perhaps the manufacturer has linked terminals to insert in the cover for this product. I was thinking I could waste/trash a segment working on a solution as I don't need all 24 fuse positions for my car. 21 gives me a few spares on my zero optioned '78. I bought 2 12 piece blocks a few weeks ago. :) |
regards, Al |
How about these 30A jumpers from Amazon...
http://forums.pelicanparts.com/uploa...1379776160.jpg Blue Sea 9217 Jumper Terminal 2500 Series, 5 per packet, nickel plated brass rated at 30A, $6.80/pkt, O.O.S. at the moment. |
I guess calling their distributor Chief Enterprises would be the best bet. |
Can anyone comment on how effective this project has been to wake up things that haven't worked for a while? It seems like a no brainer at this price, I'm adding it to the winter projects!
Fuse load rating?
Jumper strips......
When I posted this concern:
"The other concern to use this type of fuse block is the total amperage that it can handle as a whole unit. I remember somebody mentioned it in another post." I was trying to remember Fred Cook's comment in another post: "Just curious, what is the individual and combined fuse load rating for these blocks? Often, a block might be able to take a 30 amp fuse in one position but the combined load rating might only be 60 amps (for example). Since some of the 911 fuse panels will use 2, 3 or more 25 amp fuses in consecutive slots it might be overloading the panels safe capacity. Something to consider." |
Now regarding the exposed jumper strips, the original Porsche fuse blocks had some exposed jumpers. But the idea of painting the exposed metal with Plastidip or something similar is a very good idea.
Exposed jumper in origial fuseblock http://forums.pelicanparts.com/uploa...1379866077.jpg |
| All times are GMT -8. The time now is 03:50 AM. |
