Please look at this spark plug
not a good pic. is this normal or?
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 09-22-2013, 03:33 PM
Can't really tell from the pic.
Old 09-22-2013, 04:25 PM
thumbdoctor's Avatar
Need a closer photo and to best determine combustion color is to operate the engine warm and perform an engine chop at various RPMs / speeds. Equipped with your spark plug kit drive at a constant speed / RPM then turn off the ignition and roll to a safe stopping point, remove all spark plugs and keep then in the order according to cylinder they were removed from. Closely inspect the ground electrode and insulator.
Porsche, aucune comparaison
Old 09-22-2013, 05:33 PM
Make the focus on the plug, and not the pavement.
Old 09-22-2013, 05:46 PM
I added some contrast, sharpened it a little and cropped it to see it better.
Looks like a spark plug thats been driven all around normally on the street around 4 to 5000 miles including idleing at stop lights.
It's not too light from running lean and not too dark from running too rich and the electrodes don't look rounded off from eroding away during a lot of mileage.
There may be a little oil burning going on but it doesn't look like there's any heavy oil carbon build up on the ground electrode.
A person would have to know how long that plug has been running in the motor since it was installed new or freshly cleaned.
I think if you removed it after cruising steady speed on the intersate for a little while it would be a lighter tan color.
If the motor isn't smoking a lot I'd say it looks OK.
Old 09-22-2013, 06:03 PM
thank u for that. 5 of them looked like that and 1 was really white.
is that an indication that the cylinder is running lean?
Jason
81 SC
97 328is
Old 09-22-2013, 06:31 PM
T77911S's Avatar
the one that is really white is more critical than that one.
sounds like you have an air leak on that cyclinder or and injector not delivering enough fuel.
careful, dont get too close when taking a photo...
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-23-2013, 03:08 AM
